30 min runtimes
Old 08-29-2010, 02:04 AM
Default 30 min runtimes
Hi all
Can someone tell me what is the best set up to get at least 30 mins runtime from a 2 wheel and a 4 wheel drive slash?
Speed doesnt matter as it is for my 8 year old son so slow is fine so long as we can get at least 30 mins runtime .
Many thanks
Henry
Henryslash is offline
Old 08-29-2010, 02:42 AM
A 5000mah lipo should do that.
Also what esc/motor are you using in them?
Sandman77 is offline
Old 08-29-2010, 02:54 AM
Hi Sandman thanks for the reply
They are standard motors etc
Do you have to use lipo to get the result i need? Its just i want the slash to go not so fast and i hear that if you use lipo the car will nearly fly
Henry
Old 08-29-2010, 03:50 AM
You do need lipo to get 30 min runtimes. Also you can only use 2s lipos on the 2WD but you can use 2s or 3s lipos on the 4X4. A 2s lipo will give only a small boost in speed over a 6 cell nimh but a 3s lipo will have a large difference in performance over a 6 cell nimh and 2s lipo
Old 08-29-2010, 04:22 AM
Stubbs's Avatar
Trader Rating: 57 (100%+)
You can also get a Titan 550 from the E-Maxx (it says Monster 550 on the motor label instead if Titan 12T). It's a 23T vs. the stock Slash 12T. It will slow the truck down considerably, and give you more run time.
I did this with my 4 year old....started him on a 5000 mAh NiMH, 23T, in training mode. He would normally get about 40 min. of run time. He's steadily progressed through full speed on the 23T, training mode on the 12T, and now to full speed on the 12T.
Yes, Lipos will make the truck go faster, but it's mainly because of the additional voltage Lipos have over NiMH. If you want to keep the same voltage as the NiMH, but have the relatively constant discharge curve as a Lipo, then you should purchase s LiFe pack. As an extra bonus, they're also safer than a Lipo.
Stubbs is offline
Old 08-29-2010, 06:45 AM
kman16jr's Avatar
Trader Rating: 53 (100%+)
+1 you took the words right outa my mouth.
kman16jr is offline
