Old 08-27-2010, 11:34 AM   #1
Default Turnigy 5200 Lipo battery
I bought a Turnigy 5200 20c lipo at the track last week..Now when I go to charge it it says CONNECTION BREAK. Even looking at it with a meter, it does not show any voltage or continuity...Any suggestions on what I can do??
thanks
dzuke is offline   Reply With Quote
Old 08-27-2010, 12:54 PM   #2
Trader Rating: 21 (100%+)
I guess you're checking the main power wires? Check cell voltages from the balance connector. Guessing you'll find voltage in both cells.
I'd have a hard time believing it has 0 voltage. These lipos have a small piece of PCB in the wired end and in probs like this there's usually a bad/broken connection on one of the main power wires at the pcb. Just a matter of identifying which wire is not properly connected and fixing the connection.
Duster_360 is offline   Reply With Quote
Old 08-27-2010, 01:06 PM   #3
sent you a pm
Old 08-27-2010, 01:25 PM   #4
Location: anywhere I can race 2wd dirt,and 1/12 onroad in MI.
Trader Rating: 39 (100%+)
x2. had one of my zippy batteries do this. Just a poor solder joint where the cell tab is soldered to the board.A couple minutes of soldering and some CA to put the case back together and Viola! good as new, actually better since it now has a good solder joint in place of a poor one.
*Vandal 4wd Late model*XXX-T sprinter*Micro scale specialties 1/24 'rock monster' crawler*MSS Micro-Rail*MSS Micro-Funny*MSS Micro-Outlaw*
2wdMod is offline   Reply With Quote
Old 08-27-2010, 02:23 PM   #5
Originally Posted by dzuke View Post
sent you a pm
Answered....
Sometimes you get a lipo with issues like this from HC/HK. You need to be prepared to deal with it or just buy an extra lipo each time.
The other common prob is a low voltage cell. That can be dealt with as well.
Old 08-27-2010, 02:57 PM   #6
I did buy 2 of them and the same thing happened to both of them..1 cycle of charge and then nothing...
Old 08-27-2010, 05:11 PM   #7
My venum charger did the same thing. took balance block apart and their was a broke copper part on circut board. called venum up and they sent me a new one. no problem since
mfcoupe32 is offline   Reply With Quote
Old 08-27-2010, 07:33 PM   #8
Took battery apart, everything looks to be soldered and in place..i guess the battery is toast...Out some $$$$
Old 08-27-2010, 10:37 PM   #9
koolwhipman's Avatar
Trader Rating: 60 (100%+)
Can you get a second oppinion from a shop or another racer? Have you tried a balance port voltage display?
Timewarp R/C
koolwhipman is offline   Reply With Quote
Old 08-27-2010, 11:07 PM   #10
zrxrxr's Avatar
Batteries don't usually just flop like that. Doesn't seem right. Usually they swell first or go out with a bang. Even then they have some voltage.
zrxrxr is offline   Reply With Quote
Old 08-27-2010, 11:32 PM   #11
You didnt run them dead did you??Just asking . i can understand 1 of 2 , but for both to go bad in 1 charge, something else is happening there.
Old 08-28-2010, 01:13 PM   #12
No did not run them dead..Have the voltage at the main plug, but cannot charge, and nothing when plugged into my sc10 truck..
Old 08-28-2010, 01:28 PM   #13
This has got to be some kind of bad or intermittent connection problem.
Nothing else makes any sense....
Old 08-30-2010, 09:25 AM   #14
Well it worked when I first bought it, and charged it.. After 2 runs went to recharge and nothing..
NEW LIPO BATTERY TURNIGY 5200mAh 2S 30c and 5000mah 20c hardcase otaiseng Malaysian Forsale-Trade 40 07-03-2010 11:02 PM
Turnigy 5200 2s Hard Case 30C dman7 R/C Items: For Sale/Trade 48 06-04-2010 07:15 PM
SCRT10/HV 4.5 GTB/TURNIGY 5200 specgie R/C Items: For Sale/Trade 16 03-04-2010 02:02 AM
