sensored running sensorless?
Is it possible for a sensored system to be running sensorless? meaning the sensor cable removed
if so, will there be any programmable item/s that will not function? pros & cons pls thanks |
P
Originally Posted by J-Force
(Post 7850812)
Originally Posted by LunchboX3904
(Post 7850923)
P
Need more info. What esc and motor? I have a hunch ur talking about a novak havoc system....if thats the case then no, it cant run a sensored motor. nope, i'm running SP R8 and Cirtix 2200kv.. |
(Post 7851313)
"Featuring sensored or sensorless operation" http://www.speedpassion.net/en/produ...?p=EXA93301C8X |
if the motor is sensored, can it run sensorless by just removing the cable? what effect will it have? thanks a lot
(Post 7855774)
how about the esc programming, will all the functions still operate without the sensor cable? many thanks
could you do it with a MMpro and a Tekin?? I had some problems at my last race and saw that my sensor cable wires were barely connected in the plug, basically torn at both ends :weird: I was able to borrow another sensor cable and no issue's from there. I was afraid to run it w/o the sensor cable and ruin something.
(Post 7856163)
