Old 08-19-2010, 09:47 PM   #1
Trader Rating: 20 (100%+)
Default loose on corners
I tend to loose the back end around corners with my T4. I run on clay with medium to high traction. Would changing my rear hubs help?
storytyme is offline   Reply With Quote
Old 08-20-2010, 12:22 AM   #2
mcheroke's Avatar
Trader Rating: 15 (100%+)
You could try a few things, but only 1 at a time. Adding some weight to the rear end could help. You could move your rear camber links out on the hub carriers (towards the wheel). Are you using the same tires as everyone else?
mcheroke is offline   Reply With Quote
Old 08-20-2010, 06:38 AM   #3
millerman23's Avatar
hubs are more for straight line performance. what are you running in your diff?
SC10 w/ Sidewinder 5700kv. Still need more traction (almost curred)
RC18 Just for fun
millerman23 is offline   Reply With Quote
Old 08-20-2010, 07:23 AM   #4
First thing to try is tires. Try running tires in the front that have much lower traction that the rears. I watched a guy running an SC10 which is basically a T4 set up for short course and he ran stock tires in front and proline calibers in the rear and he was absolutely the fastest car on the track.
Tires will always be the first thing to try as long as your basic car setup is sound. Starting with the stock setup on the truck and experimenting with tires will be the most productive way to change the handling.
chiro972 is offline   Reply With Quote
Old 08-20-2010, 11:11 AM   #5
Driver86's Avatar
T4 and SC10 are very similar, so here is what I did to get mine dialed in when it was ass-happy
1.Move battery all the way back against shock tower (requires FT strap or putting the little rubber hinge thingies under the battery bar.
2. 4.0 degree rear tow-in block
3. Good tires, Goosebumps, Calibers and Subcultures seem to be the favorites: I use Calibers
Do these 3 things and you'll be glued.
Traxxas Slash 4x4 Platinum -60A Hobbywing ESC 10t and 17.5t EZRun motors
Traxxas Stampede -60A Hobbywing ESC, EZRun 5400KV motor
Tamiya TB-02 60A Hobbywing ESC, EZRun 5400KV motor
Duratraxx Vendetta SC Hobbywing 25A ESC, Tacon 4300KV motor
Driver86 is offline   Reply With Quote
Micro On Road & 1/18 Off Road Nats Thread RCMadness Micro and Mini Scales 1168 11-23-2017 08:19 AM
Electric Touring / On-Road RC Screaming Wind Manila Racers 32167 05-02-2017 11:20 PM
GT class--buggy-based on road! duneland Nitro On-Road 9643 11-16-2016 04:11 AM
Bending Corners Raceways, Carpet, Asphalt, We got it! TireShredder California Racing 7617 10-07-2013 11:37 PM
DRCW carpet racing on rubber tires Cameron Racing Forum 3032 08-22-2010 11:14 PM
