Old 08-19-2010, 04:11 AM   #1
ckblood05's Avatar
Trader Rating: 15 (100%+)
Default ? on motor cooling fan ?
ok, i bought the integy blue heat-sink with the cooling fan. heres the link-
http://www.integy.com/st_prod.html?p...32&p_catid=109
well, after jumping for a bit, the fan broke off. so now im just using the heat-sink. im only running 7-cell batts. but should i get a different heat-sink like this-
http://www3.towerhobbies.com/cgi-bin...?&I=LXJD62&P=7
or will the one im using now work ok. eventually im going to 3s 30-40c lipos. i kinda want to stay away from the fans because it will probably break off again. any suggestions? thanks. heres a pic of my current heat-sink. its kinda hard to see, but you can see where it is.
traxxas t-maxx 3.3 model#4908 hopped up from the ground up!!!!!!!
duratrax 1/18 mini quake 4wd every part is upgraded!!!!!!!!!!
trinity spyder 4wd. 1/18 stock
ckblood05 is offline   Reply With Quote
Old 08-19-2010, 06:49 AM   #2
Briguy's Avatar
Trader Rating: 125 (100%+)
Send a message via Yahoo to Briguy
If you keep it geared properly you don`t need that stuff .
At Your Service Vinyl Works
Royal R/C & Hobby
Leisure Hours Hobby & Raceway
Briguy is offline   Reply With Quote
Old 08-19-2010, 08:13 AM   #3
ckblood05's Avatar
yea true. its geared 22/86 right now.
Old 08-19-2010, 08:29 AM   #4
Trader Rating: 103 (100%+)
Its true that if its geared right you dont need them but i like the fact that the cooler the ESC and motor run the longer you can expect it to last.
jrherald420 is offline   Reply With Quote
Old 08-19-2010, 09:30 AM   #5
ckblood05's Avatar
yup, i agree. i might get that one heat-sink i posted above^
Old 08-19-2010, 10:50 AM   #6
RcRacing4Ever's Avatar
what kind of temps are you coming off with? I personally wouldnt buy the other heatsink since you already have 1,just take off the bracket for the fan & you should be all good since I seen in your pic that you have an Alum motor plate & tranny case that gets rid of the heat also.
- Associated Sc10 -
- FT TC5R -
Sponsors *My Wife & My Wallet*
RcRacing4Ever is offline   Reply With Quote
Old 08-19-2010, 05:38 PM   #7
ckblood05's Avatar
im not really sure on temps. i dont have a temp gun yet. but its not real hot. yea i guess the heat-sink i got now is ok. plus the alum. gearbox. plus i got cut-outs on the body to let air in.
Motor cooling fan stops at full throttle. old-man Electric On-Road 8 05-27-2010 05:57 AM
Motor cooling fan dway100 Electric On-Road 55 08-05-2003 11:37 AM
