how do you know what kv??
You should always be around 30000 rpm's.
Battery voltage * KV = rpm.
This is a good chart to show you how to match voltage to kv...
http://www.impaktrc.com/product_info...oducts_id=3076
The higher the voltage, the more efficient things run. However, unless you are running 15+ minute mains, 4s is more than adequate.
not racing.. just playing on the track..
i am used to a .21 nitro 8ight... so i want something similiar.
would prefer decent run times yet enough power to jump the doubles and triples.
what about something like
Tekin 1/8 Rx8 Brushless System/T8 1900kV
http://www3.towerhobbies.com/cgi-bin...&I=LXWZJ4&P=ML
or
Tekin 1/8 Rx8 Brushless System/T8 2250kV
http://www3.towerhobbies.com/cgi-bin...&I=LXWZJ7&P=ML
what type of power difference between those two?
and what is best for these types?
4s?
or
4s?
Tekin T8 1900Kv is a buggy motor, while the 2200kv is a truggy motor (not necessary for a buggy).
If you choose Tekin on 4S lipo, I would rather suggest the 2050Kv buggy motor.
I am running the 1900kv buggy motor, but prefer to use 5S (18.5 volts) on this motor. That is really sweet, but heavier and more expensive batteries.
or
4s?
or
4s?
I drive a Neu 1512 1850kv on 4S lipo and it's dialed. It runs as fast as a nitro car.
The truggy motors are slightly longer, so they produce more torque. If you are just bashing, the 2200 motor is fine. You will get longer run times though with a 2050.
