Storing LiPo batteries?
So Im not going to be using my batteries for a couple weeks and wanted to store them.
I was told to discharge them to 3.7v, but how do you do this?
Im using a triton 2 eq and on lipo discharge it seems to only discharge them to 3.0v per cell...
Does anyone know how to set it up?
You're right, you can't set the discharge voltage on your charger, its 3v/cell when you're discharging and there is no storage mode. You can store lipo at voltage between 3.7 and 3.9v/cell, there is nothing 'magic' about 3.7v/cell.
You have a couple of ways to get there, run them and stop and check every so often to see what the voltage is and when its between 7.4 -7.8v, stop and put it away. This is prob going to take some time.
Run the lip normally and charge it only up to the storage value. If you go this way, use a low charge rate, you want your storage voltage to be a resting voltage and at high vcharge rate, once you stop, there will be some voltage change as it transitions to a resting voltage. This is prob a more time effective way to get your lipo ready for storage.
Thats should work, I wouldn't take them as low as 3v/cell though, 3.2 - 3.4v/cell is as low as I'd let one get. 3.0v/cell is starting to be recognized as too low and not good for a lipo.
I'm guessing you don't have a digitial voltmeter or multimeter? You really should get one. You could use that to check voltage instead of having to hook them up on charger. Use a low rate like 0.1a so if the voltage is already good for storage, you don't mess it up.
