Thinking about Going Brushless 1/8 >
Old 08-15-2010, 07:07 AM
2fst2c's Avatar
Trader Rating: 114 (100%+)
Default Thinking about Going Brushless 1/8
Ok, so I'm a nitro guy and have been thinking about playing with a 1/8 E buggy.. I know most guys run them on 4 or 5 cell lipos. Can it be done on 2s lipos and be competitive? I am wondering mainly about the efficiency. Would a 2S with say a Neu 1415/1D 4100kv motor or similar perform as well as a 1512 1800kv on 3 or 4 cell as far as run times, Heat generated, Strain on ESC etc..? Any of you run a 2S setup in 1/8? Thanks for any info you can give me.
2fst2c is offline
Old 08-15-2010, 08:00 AM
morgoth's Avatar
Your setup will draw loooots of amps. This will result in heat and I will not be efficient. Go at least with a 4S setup for 1/8 scale.
morgoth is offline
Old 08-15-2010, 08:59 AM
Trader Rating: 39 (100%+)
1/8 buggies are heavy and you can't run 2s to power one. I'm a former nitro guy myself and can testify that electric in 1/8 is a kick like no other. My only downside to running 1/8 e-buggy is that the torque destroys tires prematurely. I've spun off a new set of tires in as little as 2 trips to the track.
If I played with the ESC programming I'm sure I could get that down but its kinds of fun to pull the throttle and have all 4 tires balloon up like a drag doing its prerun burnout. On 4s 5200 Turnigy batteries I get almost 30 minutes of run time and it stays cool.
Cody01 is offline
Old 08-15-2010, 09:44 AM
2fst2c's Avatar
Thanks for the replies..I'm curious because I see the Kyosho VE is meant for 2s or 3s Max. Is it a competitive buggy in the real world? I know it can be in the hands of a Pro but the average A-B Main racer?
2fst2c is offline
Old 08-15-2010, 09:57 AM
scwrod's Avatar
Originally Posted by Cody01 View Post
1/8 buggies are heavy and you can't run 2s to power one. WRONG
My only downside to running 1/8 e-buggy is that the torque destroys tires prematurely. I've spun off a new set of tires in as little as 2 trips to the track.If I played with the ESC programming I'm sure I could get that down but its kinds of fun to pull the throttle and have all 4 tires balloon up like a drag doing its prerun burnout. On 4s 5200 Turnigy batteries I get almost 30 minutes of run time and it stays cool.
If you are going through tires that quick you either need to work on your setup or you trigger finger. I need to know your setup before I can believe the 30 minutes. Is this practice or race condition?
You can run one on 2s. We run them in an indoor track on 2s only. You have to be smart with the gearing and batts. I use the same 2200kv I use for offroad. With all that being said. It is hard on the batts but it is manageable. a 2s setup would not work on a large outdoor track unless there was a 2s only rule. I would not try to run 2s outdoors. It does work on small indoor tracks and is alot of fun and some really close racing.
It is almost like a spec class. Good close racing that boils down to driver ability.
In This video everyone is on 2s.
http://www.youtube.com/watch?v=NtplLrUxUtw
scwrod is offline
Old 08-15-2010, 11:13 AM
fallguy's Avatar
2S never tried it but like posted might be OK for small tight tracks (ones made for 12th and 10th scale)
im running 3S on my hyper 9e and think it could use more top end... still gearing it up to see where it starts to get hot. but with 15t it could be faster and its not getting that warm.
fallguy is offline
Old 08-15-2010, 03:03 PM
hakmazter's Avatar
You can run a 1800-2100kv motor with a 17 tooth pinion on a hobbywing 80 amp esc all day long and it will not heat up the battery, motor, or esc and it can be competitive on a track that size or slightly larger depending on the jumps.
hakmazter is offline
Old 08-15-2010, 03:14 PM
jmcvicker's Avatar
I run a Castle 1800kv with 4S but it's real nice on 3S for slightly tamer results and indeed could run 2S but would only do it on a small indoor layout.
jmcvicker is offline
Old 08-15-2010, 07:55 PM
2fst2c's Avatar
Thanks for all the info. I know in the winter, we run on an indoor track. It's like 80x100 and I think 2s would suffice there. That would give me time to get some 3 or 4S lipos for outdoor season if I decide I like it.
2fst2c is offline
