im new into rc racing and i have a sc10 any suggestions >
Old 08-14-2010, 07:06 PM
Default im new into rc racing and i have a sc10 any suggestions
i have a sc10 does anyone have any set up suggestions or just in general
rcracer121 is offline
Old 08-14-2010, 07:40 PM
practice, practice, practice
Sandman77 is offline
Old 08-14-2010, 07:58 PM
i can do that i actualy have a samll track
Old 08-14-2010, 08:02 PM
trick it out with rpm a-arms, front and rear, they're totally worth it. and the rpm bumper for the sc10 is great too, it holds up to a lot of punishment. and if you want better traction, upgrade to better tires, the stock ones kinda suck
Punisher72 is offline
Old 08-14-2010, 08:03 PM
ok but im kinda on a low buget im yonge
Old 08-14-2010, 08:18 PM
there's always birthdays and holidays, LOL. the a-arms aren't too expensive, like 10 or 15 bucks for fronts, and maybe about the same for rears.
Old 08-14-2010, 08:44 PM
ChrisAttebery's Avatar
Trader Rating: 121 (100%+)
First off, is it a kit, RTR, Brushless?
What kind of track are you going to run on?
Do you know what setup it has? This is a better setup than the stock RTR, and it only needs front springs and front castor blocks to make the truck much more stable.
http://67.199.85.166/racing/setups/s...ndard_2010.pdf
Good luck,
Chris
ChrisAttebery is offline
Old 08-14-2010, 09:29 PM
I think that rpm front bumper is a good buy. Its not very expensive and can save the 30.00 chassis in a crash.
I've bought a lot of stuff for mine, but 95% of the things were unnecessary.
rcannon409 is offline
Old 08-14-2010, 09:32 PM
i bought it used its got a vxl brushless sestem in it and i havent goten to the track yet my locel track is novelty rc raceway in novelty MO
Old 08-14-2010, 10:02 PM
i bought it used its got a vlx brushless sestem in it and i havent goten to the track yet my locel track is novelty rc raceway in novelty MO
30k oil in the diff or black grease and tires. Mind your gearing
http://www.comeseethis.com/gearing/Default.aspx
and tires! Don't let the rear sag too much as it makes a big difference on how it turns.
mugenlife is offline
Old 08-14-2010, 10:05 PM
ok thanks for the suggestion
Old 08-15-2010, 05:10 AM
get tyres that suit the surface of your track and replace parts with RPM parts when they break NOT before, no point replacing parts if theres nothing wrong with them.
Old 08-15-2010, 11:36 AM
blade329's Avatar
Trader Rating: 114 (100%+)
The SC10 can be your worst nightmare if it's not setup properly. If you stick with it and be patient, it's a fantastic racer. I've seen many have great success with it. Like others have said, make sure you have the right tires. The stock AE tires are absolute trash on anything other than a hard packed high grip surface. The RTR setup is totally inadequate for anything other than making donuts in the dirt.
blade329 is offline
