LRP S10 Blast RTR
Looking at putting an EZRUN Brushless combo in, what size motor and esc would best suit for just bashing?
Cheers
Cheers
are you referring to the kv of the motor or the actual size of the can
My mate has the tamiya baldre with 5.5T/60A running a 7.4 5000 Venom, to be honest it dosent seem all that fast???
Running the same gearing;
Lower turn/higher KV will give you a higher top speed
Higher turn/lower KV will give you a lower top speed with more torque. but it will run cooler - even when running the right gearing to get it to the same speed as the higher KV
Ideally, you'd go for a lower KV (to an extent) and just run higher gearing with more voltage to reach the same top speed. Your setup will run cooler
Yeah, my DB01 didn't seem that fast with a similar rated motor as well. Not sure why
Like I said though, I would try 2s first.
I'll let you know how it goes
whats betta sensored or sensorless?
Cheers
I honestly have never used a sensored motor but from what I know.
Sensored; a lot smoother take off but have a slightly lower top end
Sensorless; cog of taking off (some more then others) but nothing bad
Normally a sensored motor/ESC combo will be slightly more then a sensorless setup.
Previous Thread
Next Thread
