Servo Ratings --> Voltage Question >
Old 08-09-2010, 06:14 AM
Suspended
Talking Servo Ratings --> Voltage Question
Help...
When buying a servo... The specs are different depending on the voltage you are feeding it...
So how do you know what voltage your receiver is feeding it?
I am asking about the popular Specktrum ones like an
SR3300T
SR3100
SR300
I see that the specs of those receiver say...
Voltage Range: 3.59.6V
Isn't that the Input voltage range of the Receiver??? I can't find what the output voltage is for the servos...
Sorry if this is an stupid question.
bbecker is offline
Old 08-09-2010, 06:25 AM
Trader Rating: 21 (100%+)
Rcvrs usually have a bec inside that regulates the voltage output at 6v. Check the sepcs on yours, the othe rthing specs should tell you is the available current from the rcvr which is important if you're running a ultra torque servo that needs the current.
My bad, I was thinking nitro setup....elec setup its the esc's bec like posted.....
Duster_360 is offline
Old 08-09-2010, 06:26 AM
scottd's Avatar
Originally Posted by bbecker View Post
Help...
SR3300T
SR3100
SR300
That is the input range. It would seem you are barking up the wrong tree for the servo BEC voltage. That should be found with your speed controller. Look up what your ESC outputs for BEC.
scottd is offline
Old 08-09-2010, 07:12 AM
Suspended
Talking
So its what your ESC is feeding the Receiver which governs what is sent to the actual servo?
I am running an MMM. I see that its giving my receiver 6.1 volts. So that means my servos are getting their 6 volts???
THANKS for all your help folkls.
bbecker is offline
Old 08-09-2010, 11:03 AM
Trader Rating: 28 (100%+)
I'd break out a volt meter and see for sure if there is any doubt.
xjwolfpacker is offline
