Set-Up Stations
Normally I'm not a big fan of Integy products because they're durability is questionable at best. However, this set-up station doesn't have to worry about durability issues. has anyone used one? Two of my other friends were thinking about all going in on it together. Will it work for the following cars.
-Slash 4x4
-RC8BE
-Losi 8ight-E 2.0
http://www.amainhobbies.com/product_...n-1-8th-1-10th
If this isn't a good option, can someone recommend a good setup station? Obviously one thing that makes the Integy one attractive is that it's not too expensive, especially when the cost is shared 3 ways.
-Slash 4x4
-RC8BE
-Losi 8ight-E 2.0
Try this if your not sure of Integy's durability.
http://www.hudy.net/xhudy/products/p...1&kategoria=64
I had one and the bushings separated from the main uprights. Making them as accurate as a sundial at night…After that I went with the HUDY system and it’s been dialed...
Now maybe check with them and see if they fixed that problem..”IF” they had …then yea go for it!!! It was a great little system when it worked..
Previous Thread
Next Thread
