Which motor for SC, Novak HV 4.5 or Novak 4.5 ballistic? >
Old 08-09-2010, 09:31 AM
  #16
Company Representative
Originally Posted by teeforb View Post
What's the size of these shafts on these motors?
We redesigned our HV 550 several years ago for the 5mm shaft rotor; our experience (as mentioned above) was that the smaller shaft was not strong enough in the heavier vehicles.
We also make 5mm pinion gears for these motors---32 pitch and Mod 1.
NovakTwo is offline
Old 08-09-2010, 09:35 AM
  #17
Originally Posted by slackomatic View Post
I too am running a novak havok 10.5t in my sc10 on a cheap china sensorless ESC. It runs fine. With that said I am going to be getting a ballistic 10.5t for my slash which will be ran on a sensorless esc. The reason im going with the ballistic this time is it does not cost that much more than a havok but is completely rebuildable.
I'm not sure if the havok is able to have the stator changed out to a different wind count like the ballistic is either.
In our older motors---Velocitis, SS Pros, HVs, etc---you can replace the rotors, end bells/bearings, but not the wound stators. Our newer Ballistic series motors are completely rebuildable, including the stators.
NovakTwo is offline
Old 08-09-2010, 09:37 AM
  #18
onemilekyle's Avatar
Neu 1509 4500kv
onemilekyle is offline
Old 08-09-2010, 12:39 PM
  #19
slackomatic's Avatar
Thats what I thought I had read on the temanovak website. This is one of the main reasons I'm going with the ballistic instead of the havok. After I get the motor I can change the kv of the motor with a simple 30.00 stator instead of a another 90.00 motor.
slackomatic is offline
Old 08-09-2010, 12:42 PM
  #20
teeforb's Avatar
Trader Rating: 94 (100%+)
Thanks for chiming in Novak. Is 5mm the same size shaft as standard 1/8th scale motor shafts? Also, I believe I'll be running mod .8. As the conversion kit for the losi ten uses mod .8
Thx
teeforb is offline
Old 05-09-2011, 07:21 PM
  #21
RCaddict0's Avatar
Trader Rating: 85 (99%+)
Originally Posted by DUB_Ben View Post
can I run a 4.5 on my stock traxxas ESC from my brushless slash? Also, can i use my current pinions? Sorry had to clarify
Yea, the VXL has a sensored port on the front.
RCaddict0 is offline
