stripping out rear wheel....wtf
so as it started two separate race nights i broke the axle pins to the rear wheel in my sc10......went to lhs to purchase the solid axle pins but they didnt have them in stock, so i busted out the old drimmel and cut down and old alan key to size. perfect size i might add, fit why better then the stock pins no side to side play. Now the next race night the new alans didn't break but now it stripped out the wheel completely. could this be a trans issue or possibly slipper issue?????????
running mamba max 5700kv
14/87 gearing
mip ball diff
mip cvd axles
caliber rear tires with bead locks.......
14/87 gearing
mip ball diff
mip cvd axles
Location: Conducting aggressive board meetings at my local track
Trader Rating: 64 (100%+)
Make sure the pin is properly engaged into the groove on the wheel. Also try fresh lock nuts on the axles.
The earlier rear rims had issuees. If yours are the newer ones, which they probably are, use locktite or new lock nuts.
most of the time the rims strip because we are in to much of a hurry to get back on the track and we dont put them back in right. if you look at a new pin and rim there is a little bit of slop in them. i think when u put the allen in for drive pins they cut a little till they finally failed. get the solid pins and try again. or i have had good sucess by using traxxas hexes and rims. good luck.
ok so if i switch over to hex style.... what about the front so my rear will be 1/8 wider and front will be 1/8 narrower than rear.... sounds like a bad combo... or are u suggesting to switch all four like the is slash?
like the conversion idea for sure..also just tore down the ball diff and it took a giant poop!!!! so i am thinking this had something to do with it i am just slow i guess taking me 4 issues to figure that out!!!!!!!
We are actually working on a hex kit for the SC10 so you can use the hex style rims (less likely to strip) the hex kit will be specifically to the SC10 axle and pin size
Steve
Steve
The stock rear roll pin is just too short. It needs to be as long as the slot. Losi makes a longer roll pin (the number I need to find) Longer pin helps keep up with the torque load. You still need to use new nuts every now and then to keep them tight but you wont strip them out and the pin can't shift to one side or the other.
Dirty Word RC
R/C Tech Elite Member
Get the New Era 17mm adapters. Build your wheels with SC8 wheels
or the new DE racing 17mm hub SC wheels. You will not strip out the
aluminum adapter if its installed properly and you can completly
rotate tires side to side and front to rear. Best mod I ever made to
my SC10. As far as racing goes I have never failed a Tech because
of the Adapters as long as I am running the 2.2x3.0 SC wheels.
A few guys are running Black wheel nuts for a totaly stealth look.
DE racing makes replacment wheels now for the SC8
http://www.deracing.net/main.htm
My only concern is how much weight does this add and does it change the over all width of the truck. I stock is about 11 3/8
