Can't remove pinion gear >
Old 08-07-2010, 08:26 AM
  #16
Briguy's Avatar
Trader Rating: 125 (100%+)
Briguy is offline
Old 08-07-2010, 09:57 AM
  #17
morgoth's Avatar
Originally Posted by Briguy View Post
Just remove the screw and race it.
morgoth is offline
Old 08-07-2010, 10:22 AM
  #18
Trader Rating: 22 (100%+)
Probably to late but all that heat can damage the rotor just like running the motor to hot
cmain is offline
Old 08-07-2010, 10:54 AM
  #19
It would take rather a long time for that to happen, the casing of the motor wasn't even warm. The pinion gear was hot, and the shaft was getting slightly hot too.
ReV:-O is offline
Old 08-07-2010, 11:08 AM
  #20
Neu_Racer's Avatar
Trader Rating: 211 (100%+)
If you held a soldering iron for 3 mins on the shaft it should be a lot more than "slightly hot." Glad you got it off though. I've had that happen on a CC 2200kv motor more than once. First time I cut off the pinion with a reinforced blade and high speed dremel. Second time I used a pair of dykes as a level to pull it off. And I didn't use thread loc on either one.
Neu_Racer is offline
Old 08-07-2010, 12:07 PM
  #21
LightWire's Avatar
Have to agree with Jny.
lost 2 set screws in 2 days without lock, and i tightened them to the point that i nearly snapped my allen key.
Found one of them later melted in to the inside of my drivetrain protector plate
LightWire is offline
Old 08-07-2010, 12:11 PM
  #22
Briguy's Avatar
I`m not sure why you need to locktite them . I been racing 1/10 electric for 26 years and never needed to thread lock a pinion . If your using the cheap allen keys that come with the cars , I could see why . Do yourself a favor and get allen drivers .
Briguy is offline
Old 08-07-2010, 12:54 PM
  #23
LightWire's Avatar
haha yea, the one that came with it i couldn't even use to get the stock set screw off :P Used proper ones to put new ones in n they came out. Maybe just unlucky. sitting nicely with some blue lock, tho i haven't tried to get it off as yet, so not sure if it'll also be stuck :P
Old 08-07-2010, 02:16 PM
  #24
Neu_Racer's Avatar
on 1/10 there should never be a reason to use loctite. On 1/8e though sometimes it's needed.
I've been able to get loctite off anything with my set of MIPs
Best wrenches I've ever used!
Old 08-07-2010, 03:05 PM
  #25
brickshouse's Avatar
Just get a butane torch from lowes, only take a few seconds bri, theyre talkiin about 1/8.....hench the 6s
brickshouse is offline
