Stripped Screw in 1/8 Buggy (RC8e) >
Old 08-06-2010, 07:04 PM
Trader Rating: 4 (83%+)
Default Stripped Screw in 1/8 Buggy (RC8e)
I have a stripped screw in my new Tekno RC conversion. Rarely get stripped screws these days but every now and then it happens. It goes into the center brace and is the type of screw sunk flat into the bottom of the chassis. How do I get it out?
JB will not work. Dremel a slot on top will not work without damage to the chassis in which I can avoid.
I read about an Easy Out Left Hand drill bit for a dremel but I don't know what size I need or where to find it. I called Sears and Ace Hardware. It's a flat top 3mm hex screw and it's not even that long.
Any ideas?
DriftWoof is offline
Old 08-06-2010, 07:12 PM
jmackani's Avatar
Trader Rating: 14 (100%+)
alden grabit from Lowes.
jmackani is offline
Old 08-06-2010, 07:20 PM
brickshouse's Avatar
you could try wearing a cutoff wheel on a dremel down small enough to where you can get a line through it to use a flat head, had to do it before..easy out or left handed drill, you want it just a hair bigger than the allen size, and go SLOW
brickshouse is offline
Old 08-06-2010, 07:22 PM
I got it out. I put pressure on the brace and turned the brace little by little while heating up screw with the dremel.
For the future though, this is my biggest pet peeve of RC. Stripped screws.
This will take out the screws? Will it work for a dremel? alden grabit
http://www.bubbatools.com/Alden-Pro-...r-p/bd1025.htm
I have 3mm screws that cause this.
Old 08-06-2010, 09:59 PM
Trader Rating: 53 (100%+)
BEST RC TOOL EVER
rkhess is offline
Old 08-07-2010, 10:09 AM
Trader Rating: 21 (100%+)
What kind of screws are you using that is causing this many stripped out screws? Or is it due to the quality of the tools you're using? I use black oxide alloy steel screws and MIP drivers and EDS power driver tips and I just don't have sripped screw problems.
BTW, save your worn out cutoff wheels - they can be small enough to slot a flat head and not cut the chassis using a dremel and a steady hand. Probs I have with stripped screws are always with trades or used stuff I get.
Duster_360 is offline
Old 08-07-2010, 04:06 PM
those work pretty good but you have to go sloooooow
Old 08-07-2010, 07:35 PM
racer53's Avatar
There was a guy at our track thet would solder an old allen wrench to the screw, had alot of success, haven't done it myself, my be somthing to try if your bored...
racer53 is offline
