Novak Ballistic 4.5 or Castle Creations 5700 3.5 >
Old 08-01-2010, 07:24 PM
mopargreg's Avatar
Default Novak Ballistic 4.5 or Castle Creations 5700 3.5
I have a Ofna Hyper 10sc with a Mamba Max ESC, which one of these motors would be my best choice running on 2s lipo's? Run on a clay track with lots of turns & jumps....Thanks...
mopargreg is offline
Old 08-01-2010, 07:42 PM
bschanz's Avatar
from what i have heard, the castle 5700 is more along the lines of an 8.5T. I have the castle in a 4wd electric buggy and it gets a little hot sometimes here in south florida. I have the timing at neutral and am running pretty conservative gearing but i have vented the body and got temps down to an acceptable level. That motor has plenty of stink in it and has not given me any trouble on a 2s 5000mah lipo. i am a fan of keeping brands together and have never run the ballistic motors so i cannot give you an opinion on it. I like my CC 5700.
bschanz is offline
Old 08-01-2010, 08:14 PM
brickshouse's Avatar
a 3.5 or 4.5 is way too much motor for anything offroad, i think a 8.5 is about max you would want for a sc.
brickshouse is offline
Old 08-01-2010, 08:23 PM
MooseDrool's Avatar
Trader Rating: 7 (89%+)
the 550 sized motors are rated different. a 4.5t 550 is like an 8.5t 540
MooseDrool is offline
Old 08-01-2010, 08:40 PM
jmackani's Avatar
Trader Rating: 14 (100%+)
The 5700 will eat batteries compared to the 4.5. I have seen it first hand. I do run a 4.5 and the it can easily hang with the 5700 and get better run times.
jmackani is offline
Old 08-01-2010, 11:39 PM
kman16jr's Avatar
Trader Rating: 56 (100%+)
get the novak 550 4.5,it runs cooler and has alot more torque than the 5700 because the motor can is thicker and longer,WAY BETTER THAN THE 5700.
kman16jr is offline
Old 08-02-2010, 07:22 PM
mopargreg's Avatar
Thanks guys, I have both motors already so I'm going to mount the NEW Novak 4.5 in the truck and give it a run........
Old 08-02-2010, 07:23 PM
kman16jr's Avatar
+1,good choice
kman16jr is offline
Old 08-12-2010, 09:21 PM
Any update on this? I wasn't even sure if that motor would work with that esc. I'm thinking of buying that motor to use with that esc.
Michael76706 is offline
Old 08-13-2010, 12:19 AM
Yeti AS3's Avatar
Trader Rating: 77 (100%+)
Run sensored only and you should be alright. I had none of the glitching issues with a DX3s, AMB p/t, fan on the motor, and a ACE 1015 servo.
Yeti AS3 is offline
Old 08-14-2010, 12:43 AM
Thumbs down
I've had terrible luck with the 5700 in my Losi XXX-CR and Traxxas Slash. I was running 16/90 in the Slash, and I couldn't get it below 200 at the end of a run, so I had to cut the runs short. Geared 19/86 in the CR, I was lucky to end up at 190 after a run; (still way too hot!). If I geared down anymore in the CR, it would actually run hotter and top out too soon. I was running 25c 4000mah 2-cell lipos, and Castle told me that I needed to run a higher mah or C rating, as that rating of a battery was not delivering enough current, causing the system to run hotter. I was at a loss. I couldn't even get motor temps down if I set timing to the lowest setting. In my CR the motor failed during a run, and when temped was at 239 degrees. I will note that Castle said to send it in and they'd replace it for free, seeing as it's only a few months old, but I figure the same thing will happen when I run the replacement. I also bought a new 4600, and I'm having the same type of issues. I had no trouble with original Mamba Max 4600 for 3 years of running, but I think the quality of there new motors has been greatly reduced.
FeedThAddiction is offline
Old 08-14-2010, 12:50 AM
smokinu's Avatar
Trader Rating: 65 (99%+)
i am currently running the 5700 3.5 in my hyper and sure its fast and fun! but i have 2 heat sinks on it! and they are both under the motor and touching the chassis for heat and the motor is still in the 150s after a hard run!
smokinu is offline
