-   Electric Off-Road (https://www.rctech.net/forum/electric-off-road-4/)
-   -   SC10 ball cup problem! (https://www.rctech.net/forum/electric-off-road/420667-sc10-ball-cup-problem.html)
RC8daBOMB 07-27-2010 10:11 PM
I have a sc10(obviously) and i have been having a problem keeping the ball cups on the balls! I am running RPM ball cups and am still having the same problem :flaming:! Please help!
8ight-e 07-27-2010 10:14 PM
Maybe the ball studs have warn? I run the RPM ones, but keep in mind even those are only good for so long. I just swapped most of them over as I had a few pops during races and was tired of not finishing.
RC8daBOMB 07-27-2010 10:19 PM
Ive ran at the track (and only at the track) about 6 or 7 times now. having to replace these that often is ridiculous!
8ight-racer 07-27-2010 10:23 PM
Not crashing helps... :ha::D
RC8daBOMB 07-27-2010 10:23 PM
T-BirdJunkie 07-27-2010 10:41 PM
Associated has always had this issue as long as ThunderbirdJunkie can remember.
On his RC10B2, T2, T3, GT, NTC3 and SC10, the stock ballcups all did that.
Buy some RPMs and buy the Lunsford turnbuckles at the same time :nod:
Also, for the rears, ThunderbirdJunkie used 4-40 DuBro monster ball ends or whatever they're called (http://www3.towerhobbies.com/cgi-bin...?&I=LXJGT9&P=7)
http://i23.photobucket.com/albums/b3...0/SS851479.jpg
http://i23.photobucket.com/albums/b3...0/SS851478.jpg
8ight-e 07-28-2010 04:31 AM
Keep in mind before modding w/ captured ends when you crashed before and had a cup pop, now you will transfer this impact to a part on the vehicle.. the next thing in line will break, it may take a hit or two.. but in will happen. I've done it before and it has never worked out, best bet is be patient while you learn to drive, as you get better you won't crash nearly as much and won't have this issue. After a ball cup pops a few times I would replace it, most likely it has stretched out, even the rpm ones. For example the guy above has aluminum hubs.. so naturally all this pressure will move to that inside block, which will break when hit right, that or it will work the ball stud out of it and strip the plastic. So do you want to replace that part, or just pop the ball cup back in place? Your choice.
Driver86 07-28-2010 05:20 AM
I've been racing mine for 2+ months now and haven't had a single one pop. Haven't on my RC18 either, in fact those things were insanely hard to remove. I did replace the ones on the RC18 with Losi ones though so that I could have them be adjustable.
WillD 07-28-2010 07:06 AM
I've been running RPM ballcups for several months now without a single pop as well.
Keep in mind that if you are constantly changing your setup requiring you to pop off a ballcup that even the RPM ones will wear out quickly. In my experience as soon as you pop off a ballcup more than a few times I have to replace it with a new one doesn't fit snug enough anymore for me to trust it.
Are you running with the little white dust guards? I'm sure that helps as well.
Briguy 07-28-2010 07:49 AM
+1
Moogumby 07-28-2010 08:31 AM
I had a couple of mine pop on the rear but that was because i was using the Racers edge hubs. when i would land a jump the hub would hit the bar and pop it. I added some spacers under the ballstud and it solved the problem.
Driver86 07-28-2010 08:43 AM
That could be why mine isn't popping. I've got spacers under mine in order to get that extra camber length
HeavyD99 07-28-2010 09:40 AM
The Lunsford ti turnbuckle kit uses 3mm sized turnbuckles,not the typical
4-40 - RPM ball cups are 4-40.
So does anyone know who makes 3mm ball cups? The Lunsfords seem to pop off easily.
djtroy 07-28-2010 09:45 AM
I had my balls pop when I would turn a corner hard. Trust me I have been dealing with that forever. I swapped to RPM cups and replaced all my balls and no more issues at all.
I also had an aluminum chassis plate that was a big issue as well. I swapped alot of parts back to stock plastic and have never been happier. I am never buying aluminum stuff again.
Briguy 07-28-2010 09:46 AM
RPM ball cups pop off easier the Lunsford , all I run is Lunsford on all my cars and rarely ever pop off .
