Ballistic 5.5 vs Velineon in slash 4x4
http://www.teamnovak.com/products/br...550/index.html
i run the 4.5 but i also run 50c/100c also, novak recommends nothing less than a 35c continious rating with these motors. These motors take alot power. With the battery's you are running i would use a 5.5. fyi iused a 30c 2cell hard case name brand for some testing and in like 6 minutes i pulled it out and it looked like a 3 cell from the swelling
make sure you buy the ballistic 550, i have the hv550 which is the older version with a non-customer replaceable sensor wire. I am having problems with the sensor wire so i have to send i back to novak and hopefully i can pay a little money and upgrade to the ballistic 550. Great motor, lots of torque, no heat problems.
I beg the differ,i use the reedy 20c with 30c burst and it has not swelled up after running it for about 2 months now.i run the jammin scrt-10 with a mamba max pro esc and the ballistic 550 4.5t and it only runs about 125 After 20 minutes of running,i also run the turnigy 2s 5000mah hardcase 20c-30c and works great.The novak ballistic 550 4.5t is a great motor ,gives great torque and great smooth power(sensored is the smoothest)Now it runs better on a 40c 2s 5000mah and would recommend it but your battery will work fine.
I beg the differ,i use the use the reedy 20c with 30c burst and it has not swelled up after running it for about 2 months now.i run the jammin scrt-10 with a mamba max pro esc and the ballistic 550 4.5t and it only runs about 125 After 20 minutes of running,i also run the turnigy 2s 5000mah hardcase 20c-30c and works great.The novak ballistic 550 4.5t is a great motor ,gives great torque and great smooth power(sensored is the smoothest)Now it runs better on a 40c 2s 5000mah and would recommend it but your battery will work fine.
Company Representative
We manufacture both Ballistic 540 and 550 short course systems that are Traxxas compatible for real plug 'n play installation.
Novak TRA compatible Products
