Mamba Monster esc cutting out , ???
i have a brushless 1/8th buggy with a mamba monster and 1800 kv motor ,and am using a High Draw futaba brushless servo with steering ,now i feel when i push my car hard with lots of turning (Ie BASHIN) ,
it cuts out for a milli second every now and then ,but i notice it.. is it the motor and servos suckin too much power at the same time ,i heard stories about external batteries and becs ,is it for this reason ?????????? |
Originally Posted by Gen
(Post 7724512)
Oh and the on/off switches go bad. Its the first thing I remove before installing them.
Originally Posted by CSaddict
(Post 7724517)
(Post 7725161)
so you saying short out the switch ,,solder wires together ?????
i cut off my switch and and just shrinkwrapped it so it will turn on as soon as plug in the battery.My wires are just twisted together and have heatshrink over the wires and then ziptied the wire to the positive or negative wire so it does flop around.:nod:
i can take a pick if you want to see it .:nod:
here are some pics of mine.:nod:
I had one do this and it was because I had something binding in my servo and it was trying to draw too much power. Turn your servo left and right and make sure that the linkage isn't hitting anything. Hope this helps.
thnks ,will try
I know nobody has posted here for a while.
I am having a power cut issue with 2 different mamba monster ESC. When I am running for reasons I cannot see the power totally cuts out, sometimes just the motor power and the servo still runs, or everything cuts out and nothing runs. You wait a few seconds and the ESC re initialized and beeps back to life. I have removed the on/off switch on both, but they are still doing it. It has even happened mid air, the power cuts and brakes lock on. What should I do? I have cleaned the internal board of the ESC, my receiver, checked for damaged connections... Everything I can think of. Help!!!!! |
Originally Posted by GGREAVES
(Post 13224024)
I am having a power cut issue with 2 different mamba monster ESC. When I am running for reasons I cannot see the power totally cuts out, sometimes just the motor power and the servo still runs, or everything cuts out and nothing runs. You wait a few seconds and the ESC re initialized and beeps back to life. I have removed the on/off switch on both, but they are still doing it. It has even happened mid air, the power cuts and brakes lock on. What should I do? I have cleaned the internal board of the ESC, my receiver, checked for damaged connections... Everything I can think of. Help!!!!! I have a Losi 8ight-e 3.0 with the Mamba Monster 2/2200kv motor not running external BEC,internal BEC is set at 6v,I ripped off the fan on the Mamba monster2 and Castle Creations Cooling Fan & Shroud and replaced them with NEW Muchmore Racing Motor/ESC Cooling Fan 30x30mm MR30FAN Hitec HS-7955TG Digital Servo, Futaba 4PLS S-FHSS Telemetry Radio/R304SB Receiver I've had this about a month and no problems with it yet,(touch wood). |
(Post 13224024)
Originally Posted by rotachoc
(Post 13224548)
Is it getting to hot and shutting down maybe????
Originally Posted by spookie
(Post 13224621)
Did you try another set of batteries? My emaxx used to do that when the batteries started getting close to the lvd. setting. The batteries sag voltage, then rebound and off you go again.
Also it does it when I land flat on a large jump, but it's unpredictable. |
