Kyosho Ultima SC-R Thread >
Old 01-13-2014, 09:35 PM
  #4861
mojoman81's Avatar
Trader Rating: 26 (100%+)
Originally Posted by chillindrdude View Post
does anyone center line mount their electronics on the SCR?
any advantages doing so?
I bought a center esc mount from Snr , I dont know if they still have them '
mojoman81 is offline
Old 01-15-2014, 01:42 PM
  #4862
Diff Balls's Avatar
Trader Rating: 39 (100%+)
I just picked up a scr-sp, what is a good setup to start with for an outdoor, med to med low traction?
Diff Balls is offline
Old 01-18-2014, 12:12 PM
  #4863
mojoman81's Avatar
Start with the box stock setup , its the baseline setup . Its hard to tell someone else how to setup there truck without knowing what the track looks like and what kind of driving style you have .
Old 01-20-2014, 08:54 PM
  #4864
Trader Rating: 32 (100%+)
email me info @ factorymotorsports .net
i have a setup that i have been giving out and is a great all around setup. almost 100% said it worked great for them. All kinds of tracks and drivers.
Pimpin is offline
Old 01-21-2014, 09:55 AM
  #4865
Default setup sheet
Sent you an email Pimpin for the setup sheet
thanks
Rocktoy71 is offline
Old 01-21-2014, 10:27 AM
  #4866
Grandturk's Avatar
Are thee any mods to allow the use of 0 offset wheels such as SCTE/22SCT wheels or are you stuck with Kyosho wheels?
Grandturk is offline
Old 01-21-2014, 10:49 AM
  #4867
Super Moderator
Kraig's Avatar
Trader Rating: 80 (100%+)
I know you can use the SC10 wheels if you wanted. I do have some Losi wheels that I could try tonight when I get home after racing.
With the different off-sets you tend to narrow the vehicle which I can see it being a nice tuning option.
Kraig is offline
Old 01-21-2014, 11:05 AM
  #4868
Grandturk's Avatar
I imagine they would be make it quite a bit too narrow without widening the hub.
Old 01-21-2014, 12:22 PM
  #4869
Super Moderator
Kraig's Avatar
The Losi wheels, yes that would be narrow. When I ran the SC10 wheels the truck just seemed to change direction so much faster but it did have its trade-off's.
Kraig is offline
Old 01-21-2014, 12:39 PM
  #4870
no, the kyosho is already 6mm too wide
knapsty637 is offline
Old 01-21-2014, 02:44 PM
  #4871
The Local factory driver turned me on to these rims.
AKA Cyclone 23001. I have used these for 2 years now and they are legal and durable, never a problem.
twolf is offline
Old 02-03-2014, 10:04 AM
  #4872
Moderator
Posvar's Avatar
Trader Rating: 470 (100%+)
Posvar is offline
Old 02-03-2014, 12:35 PM
  #4873
Moderator
Posvar's Avatar
Posvar is offline
Old 02-03-2014, 12:44 PM
  #4874
Moderator
Posvar's Avatar
Kraig, can I start a new page yet?
March 15!!!
Posvar is offline
Old 02-06-2014, 09:29 AM
  #4875
84 GT 5.0's Avatar
Trader Rating: 26 (96%+)
hi guys I'm in need of setup help with my scr-sp. The truck has a bad mid corner push, initial turn in is good but mid corner the truck becomes a bull dozer. Then the other issue is corner exit and straight away traction I have none. The track surface is inconsistent hard pack and dusty in some parts loamy in others usually its run wet. Tires of choice are either city blocks in super soft or gridirons/snipers in same compounds.
My setup is as follows
Front-
Yellow springs
Outer hole on tower middle on arm
Camber links inside hole on bulk and inside on caster block no spacers
32.5 wt oil
-1 camber
Rear-
Red springs
30wt oil
Middle hole on tower inside on the arm
1* toe carriers
Camber links on bulk are in middle hole and on hub in the farthest hole out(sp2 style strc hubs has 4 holes) no spacers
I have aluminum suspension hangers but don't know if they are wide or narrow and what the difference is. Any help is much appreciated.
84 GT 5.0 is offline
