Kyosho Ultima SC-R Thread
#4591
We are currently expanding more into Off Road parts, accessories, kits, etc;
Stop by our site and check us out - we have ultra-competitive prices and are adding lines and products on a daily basis.
#4595
Cactus Classic 2013 - 17.5 Blinky Short Course
#2 Matt Gilbert - Yellow/Blue
SpeedtechRC.com Kyosho SCR-SP
SpeedtechRC.com 6500mah 70C Lipo
Speed Passion Reventon Pro Esc
Speed Passion MMM 17.5
MIP Diff Kit
MIP CVD Kit
Proline Ion Tires - MX compound F/R
Proline Renegade Rims - Slash Rears F/R
Proline Flotek Body
http://www.youtube.com/watch?v=3aM-KOIY7TM
MIP Diff Kit
MIP CVD Kit
Proline Flotek Body
#4596
Thanks. And yea the temp was def higher than i would normally run but for a 10minute a main i didnt want to gear down and lose all my power. The speed passion motor actually never faded the whole race so it all worked out.
Thats cool to hear! And thank you!
Thanks kraig. I had to strap it up in the last half of the race to win that one. Raced lavery clean in the beginning then got done dirty a couple times later after i got by him.
Hoffmans roof slide pass on me was epic!!
#4597
anybody got an idea of the ball park gearing for a med size outdoor clay track. I have a tekin gen 2 10.5t motor and a Tekin rs pro esc. Thanks.
#4598
Moderator
Trader Rating: 470 (100%+)
Try 21/82!!!!
#4599
Hello all.
Have a small issue. Coming off the straight onto either a sweeper or a 90 degree left turn my rear end washes out. I have to go in, dive the truck in and kind of counter steer it o I don't loose it. Any suggestions.
Diff isn't tight
-2 rear camber
Soft tires
28mm ride height
30 weight oil front and back.
Diff isn't tight
-2 rear camber
Soft tires
28mm ride height
#4601
Hello all.
Diff isn't tight
-2 rear camber
Soft tires
28mm ride height
Diff isn't tight
-2 rear camber
Soft tires
28mm ride height
32 mm front ride height and 28-30 in the rear. Your diff shouldn't be too loose. When u "diff out", u are essentially putting all the lateral force on the outside tire and then whatever tracking the inside tire makes is pushing the truck forward. Depending on how the traction is, your just making the situation worse.
For oil, I run 32.5 front and 27.5 -30 rear so ur not off there.
#4602
Hello all.
Diff isn't tight
-2 rear camber
Soft tires
28mm ride height
Diff isn't tight
-2 rear camber
Soft tires
28mm ride height
funny you don't mention 90 degree RIGHT hand turns...
if it only does it to one side I'd look for "issues"
#4603
Regarding weighing the corners of our truck and the affect of shock collar adjustment.
U should weigh the corners without springs. Then after the springs are on adjust collars for the same balance. Frankly I doubt most of us would ever feel a weight difference on the four corners. But I am reassured in the back of my mind somewhat when I get it "close enough" on the scales when laying out components and such, and let the collar thing just be a height/shock adjustment. When you move the collar it's the same thing as the guy stuffing that big wrench in the back window of a nascar, (weight "jacking") so in fact adjusting the collars does shift the weight balance of the car (we all know that). Doesn't mean squat if your not rubber side down ALL the time. I also believe lighter is better so I generally "balance" my car with the components and only use lead when neccesary.
#4605
Go -1 on the camber front and rear. U very well may not have the contact patch u need for accelerating out of the turn and this causes your rear end to just keep rotating. A longer camber link might help u out as well but I don't know what ur set up is right now.
Tract is hard packed slightly dusty with good traction.
I'm not really running anyone's set up just put things where the tune with camber links suggested for what I was looking for. (Side bite) its always done it though.
I got the lipo all the way in rear (5000mah) with the stock kit rear springs. I did raise it a bit and put a 4000 mah lipo and it seemed as it didn't do it as often, maybe I was bottoming out?? Someone suggested me to put my rear top shocks in the middle or outer hole in the top tower since I'm on the inside hole..
