Kyosho Ultima SC-R Thread
#4546
I have been running the new MIP cvd's for about 3 weeks now and the axles seem to hold up well but I am not a fan of how their hex fits on the keyed axle AT ALL. The hex is almost impossible to get on the axle straight and the little set screw they use (.05) drives me nuts. They use that same size set screw in the CVD also.
The 2 problems I have found with the wheel hex are as follows:
1. The aluminum is WAY too soft. Give it 3-4 good race days and you will see where the hex starts to round out on the inside causing slop.
2. When you go to tighten the set screw on the hex the whole hex wants to tweak the way you are tightening it on the axle (cause of the slop). At first you dont really notice it but once you put your wheel on and give it a little throttle you will see how much the wheel wobbles.
The only work around I have come up with was before tightening the hex set screw, put an old bearing over axle and then install your wheel nut (without the wheel), tighten wheel nut so that it pushes the bearing into the hex and then tighten down the set screw. The bearing helps align the hex on the axle but even doing it this way was not perfect.
I like the keyed axle idea but the hexes need some refinement.
I'm going to go back to my stock Kyosho swing shafts and FLM axles. Never had issues with that combo.
Just my $.02
Just my $.02
#4547
Just my $.02
Just my $.02
#4548
I had the same fitment problems you mentioned, until I took out all the shims. The hexes fit perfect now, no problems at all. You have to remove all the shims for the hexes to fit properly. Even though I have only one practice day and one race day on these parts, I have had no problems with the hexes rounding out.
Please keep me updated after you have a chance to run on them for a little and let me know how they are holding up.
Thanks!
#4549
Not sure removing the spacer I have is going to do much except allow the hex to get a little closer to the hub. The problem is the inside of the hex is rounding out causing the slop. It's only rounding out a smidge but it's enough to cause major wobble if it's not on there exactly perpendicular to the axle. And I only run mod so any little vibration is amplified!
Thanks!
Thanks!
#4551
What are the best aftermarket wheels for this truck?
#4552
Moderator
Trader Rating: 470 (100%+)
#4553
Moderator
#4555
Has anyone raised the esc to mount in the middle rear?
#4556
help guys - The current (if I can find one) Ultima SC-R SP. I have never owned a Kyosho SCT. Is this kit worth the money? OR wait for I guess is a new one coming soon? If I buy an SP - what upgrades do I need right out of the box? Thanks.
#4558
I have been making some tools for kyosho cars for a couple months now and would love to share them with as many kyosho drivers as possible. The first tool is a kyosho shock tool for removing the shock cartridge, its a great replacement for the one that comes with the kit and strips out easly. It costs $12 in the u.s and 15 overseas. the second tool s a turn buckle wrench that has three sizes on it. the one side has 2 sizes in it that fit the kyosho turnbuckles as well as the lundsford and ae turnbuckle. it will also fit durangos and any car with a 4mm turmbuckle. the other side is 5.5mm and fits all kyosho 10th scale trucks, the losi 4wd sc and some 8th scale vehicles This wrench is $17 in the u.s. and $19 for over seas. if any of you are interested please email me at [email protected] as i am not always on the forums. thank you for your time and i hope to be able to provide some of you some great tools..
#4559
Mads- Kyosho has been out of SC trucks for quite some time. A new SC truck is in the works based off the RB6 platform. I already have some on order and they don't exist yet - heh heh.
I have a ton of Kyosho parts in stock as well, (not yet on website) so don't hesitate to call. Can't wait to rub fenders with you soon!
