Kyosho Ultima SC-R Thread
#4532
Guys does this sound correct? I have 20g on top of bulkhead, 15g on rx side which also has transponder and stuff on that side, i then have no weight on the other side because I have esc there. Full length battery pack all the way forward. I then also have alum hubs and hangers.
#4533
#4535
I am pulling a senior moment. Rebuilding my diff. Had it apart for a few days. What side does the diff screw head go on, left or right? Any help would be great.
#4537
Thank You
#4538
Do blitz front axels work on this truck? Or does it need some modification for them to work?
Daryl
Daryl
#4539
There is no "correct". You run weight in different places, depending on your weight goals. I run 0 weight in my SCR, with a shorty. (well.. I run a 10 gram next to my receiver for balance). But that's it. Super high traction, lighter tends to be better. Medium or low traction, you might want a heavier truck for more grip. 100% depends on the rest of your setup, and the nature of your track and surface.
#4545
The 2 problems I have found with the wheel hex are as follows:
1. The aluminum is WAY too soft. Give it 3-4 good race days and you will see where the hex starts to round out on the inside causing slop.
2. When you go to tighten the set screw on the hex the whole hex wants to tweak the way you are tightening it on the axle (cause of the slop). At first you dont really notice it but once you put your wheel on and give it a little throttle you will see how much the wheel wobbles.
The only work around I have come up with was before tightening the hex set screw, put an old bearing over axle and then install your wheel nut (without the wheel), tighten wheel nut so that it pushes the bearing into the hex and then tighten down the set screw. The bearing helps align the hex on the axle but even doing it this way was not perfect.
I like the keyed axle idea but the hexes need some refinement.
I'm going to go back to my stock Kyosho swing shafts and FLM axles. Never had issues with that combo.
Just my $.02
