Kyosho Ultima SC-R Thread >
Old 01-30-2013, 07:56 PM
  #4426
Mr.juarez's Avatar
Trader Rating: 37 (100%+)
What will the new truck called?
Scr-sp v2
Scr6
Just curious....
Mr.juarez is offline
Old 01-31-2013, 02:52 AM
  #4427
Hoese37's Avatar
Most likely SC6.
Hoese37 is offline
Old 01-31-2013, 08:33 AM
  #4428
Gayosaka's Avatar
I have a concern about up-travel on my SC-R. When the suspension is fully compressed, the chassis can't touch the ground. Is it the same for you too?
I had the problem with the front suspension but solved it by using short shock ball ends. However on the rear, I am already using short shock ball ends and top. I know this is not good for bump handling as well as durability, as the suspension takes most of the landing forces instead of the chassis. In fact, maybe this is why so many of us are breaking wheel axes.
My car started its life as a RTR, I upgraded it to almost full SC-R SP specs : big bores, tranny, ball diff, turnbuckes, alloy suspension holders, etc. Are the non-RTR towers any different?
Gayosaka is offline
Old 01-31-2013, 09:46 AM
  #4429
Super Moderator
Kraig's Avatar
Trader Rating: 80 (100%+)
I just checked mine and the chassis bottoms out but I have my rear eyelets unscrewed at least 1 turn.
Kraig is offline
Old 02-01-2013, 10:14 AM
  #4430
sbrewer's Avatar
Trader Rating: 20 (100%+)
I just listed one if anyone is interested
http://www.rctech.net/forum/r-c-item...r-sp-artr.html
sbrewer is offline
Old 02-01-2013, 03:00 PM
  #4431
Gayosaka's Avatar
Thanks for checking that for me. Unscrewing shock eyelets don't change uptravel (unless the shock shaft is bottoming on the shock cap!).
I think that my issues come from running thick antisquat shims under both rear arm holders. Running on high-grip astro, I want a high roll center but this might be hindering uptravel too much.
I will play with the links instead.
Gayosaka is offline
Old 02-02-2013, 03:28 PM
  #4432
GREGORY!'s Avatar
Hello guys .I want to ask you if there is any other option for the internal gears of the gear diff except the steel kyosho ones. Can I use from other company?
GREGORY! is offline
Old 02-02-2013, 07:42 PM
  #4433
Mr.juarez's Avatar
dont know never ran gear diff. you should try a ball diff.
Old 02-03-2013, 06:35 AM
  #4434
mojoman81's Avatar
Trader Rating: 26 (100%+)
Whats wrong with the stock diff gears ? And Yes the ball diff is a whole lot better .
mojoman81 is offline
Old 02-03-2013, 07:21 AM
  #4435
orangutanracer's Avatar
AFAIK
You only got 2 choices for gears.
VZW424 Precision cut steel gears -$$$$$
UM610 Differential Bevel Gear Set- much cheaper.
orangutanracer is offline
Old 02-09-2013, 07:25 PM
  #4436
Rfury's Avatar
I just want to put this out there...
I have a SC-R SP I would like to sell. I will be posting a thread in the for sale section tomorrow after I clean the truck up. I am looking for $200 shipped. It has a few tires and spares. Reasonable offers will be considered. I have 2 RB5 SP2/WC rollers as well and combo deals can be worked out.
Rfury is offline
Old 02-10-2013, 07:48 AM
  #4437
kyle3333's Avatar
Will the JConcepts Hi-Flow body fit this truck? Also, I assume SC10 wheels don't fit this truck.
kyle3333 is offline
Old 02-10-2013, 08:50 AM
  #4438
Rfury's Avatar
Well, that didn't take long. I didn't even get to cleaning it up before it sold.
Yeah the hi flow will fit. Just use the holes marked for the Slash. and no, SC10 wheels won't work. You can use any wheel that fits the Blitz or 2wd Slash rear or 4wd Slash.
Rfury is offline
Old 02-10-2013, 03:21 PM
  #4439
SAMCRO's Avatar
Is the SC-R SP and SC RTR based on the same platform? I have been wanting to get away from my SC10, but want to have a minimal investment until the new K truck is released.
If they are the same platforms, what are the major upgrades on the SC-R SP besides the velvet shocks?
SAMCRO is offline
Old 02-10-2013, 03:31 PM
  #4440
Rfury's Avatar
The shocks and a ball diff are the 2 big items.
Rfury is offline
