Kyosho Ultima SC-R Thread
#4382
what part do they screw into?
#4383
For some reason whe they made the SC-R they didn't adapt the same design as the RT-5. The two screws that go into the steering rack assembly do not have nuts called out in the instructions. So you have to put 2 2.6mm locknuts on them so that they do not come apart. Just tighten them enough for them to move freely. I also replaced my bushings with bearings. Works awesome.
#4384
Thx for the quick response, will be putting on the lock nuts to fix the problem.
#4386
they screw into the arm of the servo saver, those little spacers need to be there, and the washers too. Page 14, step 5
http://www.kyosho.com/jpn/support/in...IMA_SC_R_m.pdf
#4387
http://www.rctech.net/forum/search.p...rchid=15139057
I ran 32-34 (orion esc and motor) on a medium size clay track with no boost, dropped a couple teeth depending on the boost.
#4391
Super Moderator
I am glueing the two plastic pieces together. I also went a step further by locking down the spring but like a previous poster said the bearing wasn't sitting in the nut anymore and it caused it to move around. So I cut down the length of the post so the bearing would sit in it. Then I took another bearing and put it on top so the arm wouldn't move up and down.
#4392
#4394
Running 17.5 blinky, novak balistic and Kinetic
0 toe front 2 rear
2 camber front and rear
35w front 32.5 rear
kyosho springs 65 and 70 (not sure which is which old not color coated)
top hole uper front and middle bottom
rear shock bottom hole on top and outer hole bottom
Arms less than level
I am really happy with how the truck sucks up the track and stays planted but unless I tap the brakes to wip it around it just dont turn well...and off power steering is a struggle. everybody says that is just the way it is. I am thinking now I need some toe in?
0 toe front 2 rear
35w front 32.5 rear
