Kyosho Ultima SC-R Thread >
Old 11-02-2012, 09:15 AM
  #4126
Trader Rating: 32 (100%+)
braaaap!
Pimpin is offline
Old 11-02-2012, 09:19 PM
  #4127
eper's Avatar
Trader Rating: 14 (100%+)
NICE1NICE1
BBRROTTT!
eper is offline
Old 11-03-2012, 07:12 AM
  #4128
Can you nstall the losi scte 4x4 shocks right onto the scr with no problems?
J-RO is offline
Old 11-03-2012, 07:22 AM
  #4129
eper's Avatar
you wouldnt want to run those. what shocks do have on there now
eper is offline
Old 11-03-2012, 10:11 AM
  #4130
would they not be better than the regular sized velvets?
J-RO is offline
Old 11-03-2012, 11:07 AM
  #4131
asc6000's Avatar
Trader Rating: 15 (100%+)
i'd use the velvets but if you have a set of losi's layin around mount'em up and try'em.
My spare losi shocks went on Axial and HPI cars.
asc6000 is offline
Old 11-03-2012, 12:15 PM
  #4132
Originally Posted by eper View Post
headbasher, how did you gearing change go, did it fix your problem?
I am still working on the back end staying put on turns, but am making progress. I am using the same gearing( 18/84) as before which seems to work nice on my track.
I added weight in the back and I'm up to almost 3.5 oz under the rear shock tower. I also went from -1 rear camber to -3. Those changes have made the truck way better in the corners. I am able to run pretty smooth now. I will keep working on the settings etc... might remove some weight from the front to make it more balanced.
headbasher is offline
Old 11-03-2012, 01:38 PM
  #4133
Trader Rating: 22 (100%+)
I am about to finally get to race this truck, and was wondering which setup I should start with for a very high bite wet clay track. The track is medium in size (80ft straight), and the clay gets very tacky. We usually run clay or gold compound tires like bar codes, and switches. Thanks for the help.
rcmiket is offline
Old 11-04-2012, 05:27 AM
  #4134
eper's Avatar
i personally like to run all my cars with the stock setup and go from there, other guys like to start with one of the tebo setups. so its really up to you where to start, there are lots of setups at petit rc
eper is offline
Old 11-04-2012, 11:05 PM
  #4135
Oasis's Avatar
Trader Rating: 38 (100%+)
Just got a used SC-R SP and it didn't come with any rims/tires what off-set is it?
Oasis is offline
Old 11-04-2012, 11:13 PM
  #4136
R/C Tech Elite Member
thecman26's Avatar
Trader Rating: 105 (100%+)
I always ran slash rears on my SC/R unless ya want a lil more offset, then go with the slash fronts.
thecman26 is offline
Old 11-05-2012, 04:47 PM
  #4137
eper's Avatar
i'd say no losi shock is better then a kyosho shock
eper is offline
Old 11-05-2012, 05:10 PM
  #4138
Trader Rating: 17 (95%+)
Silly question but not sure about it. When you set ride height do set it with battery on or off truck.
svillegas is offline
Old 11-05-2012, 05:20 PM
  #4139
mojoman81's Avatar
Trader Rating: 26 (100%+)
With the battery in of course thats how you will be driving it .
mojoman81 is offline
Old 11-09-2012, 09:14 PM
  #4140
Normally I would agree, but the stock springs on the SC-R are waaaay too stiff. So I did the Tebo setup.
rcmiket is offline
