Kyosho Ultima SC-R Thread
#4096
#4097
Has anyone tried the sc10 4x4 shocks on the scr? Is it even possible? How do they compare to the kyosho big bores for performance if they do work? thx
#4100
I love it: An AE team driver saying that AE stuff is junk... Go Team Kyosho!!!
#4101
I didn't try them on the scr but I did on the scte. Pure junk!!!! Always leaked and needed rebuild every 2 weeks. I just rebuild my scr that I bought new 8 months ago and the shocks were full, slight black tint and never leaked a drop. Even some people locally are putting them on the losi scbs
#4102
Quick q, when following tebo a set up it calls for -1 camber and toe. The manual says to keep the front buckles at 31mm and the rear at 38mm. They are positive camber as if now but do I really have to keep them at 31/38? Or whatever they end up after they are set at the -1 camber?
#4103
#4104
I know that alot of people talk about rear axles and them bending and/or breaking on them. Well since running the MIP cvd's i havent had a single issue and times when i would have thought it would be bent after landing on it wrong but nope, they are still straight! Highly recommended!!
http://miponline.com/store/mip12153.html
#4105
#4107
That's crazy the idlers not lasting. Is your bottom screw tight that holds the transmission cases? (Its just one screw thats hiding way in the rear bottomof the case) Are your bearings good inside the transmission? When you mess with the clutch do you know for a fact that the gold looking spacer/collar that slides into the top shaft and transmission cases is there? I have not have any issues with my black one since new 8 months ago and I'm running a x-12 7.5 with full punch control, locked diff and a pretty tight slipper. I do wheelies at time when landing off of a jump and wot it
#4109
nice ill def be getting a set of these...im having some trouble with blowing idler gears on my mod sc set up,,,i have used both the black and the white colored plastic ones and have had simillar results with both..i am doin the regular slipper adjustment that i usually do wich does slip when i test in on the table or on the floor but for some reason my idlers havent been lasting more than a few days of driving..only thing i can think to do is run the slipper looser and i feel like it will be slipping to much that way,,anyone else ran into this problem,.? or have an idea of what i may be doin wrong..thnks in advance
Adjust on the track (not holding tires) and I bet your problem goes away.
#4110
