Kyosho Ultima SC-R Thread >
Old 04-17-2012, 06:20 PM
  #3556
Super Moderator
Kraig's Avatar
Trader Rating: 80 (100%+)
J-RO, If the servo saver is loose it will feel that way.
Kraig is offline
Old 04-17-2012, 06:59 PM
  #3557
Changed the servo saver, same thing happened. So i held the tire to restrict the steering and checked to see if the servo was moving inside the saver and it was all solid. Could it be that the servo is not getting enough power from the esc and batt? Im running a Savox.
J-RO is offline
Old 04-17-2012, 07:05 PM
  #3558
Trader Rating: 94 (100%+)
NVM Got some Thanks!
Eric Tomczyk is offline
Old 04-17-2012, 07:21 PM
  #3559
B00t13g's Avatar
You won't have as much steering on the power.
B00t13g is offline
Old 04-17-2012, 07:22 PM
  #3560
Super Moderator
Kraig's Avatar
Make sure it is tight otherwise you are getting nowhere. I thought mine was tight and did the same thing you did but on the track it wasn't. So I glued the pieces together with my fingers.
What speed control are you running? If the bec can't handle the load then yeah, that could be possible.
Have you tried to walk the truck off of the pipes when it gets stuck?
Kraig is offline
Old 04-17-2012, 07:26 PM
  #3561
Have not had the truck on track yet, im using the novak gtb 2 esc, trying to get ready for Ironmaximus this weekend.
J-RO is offline
Old 04-17-2012, 09:46 PM
  #3562
samuelsonmark71's Avatar
Trader Rating: 22 (100%+)
Have you installed a capacitor to the reciever yet to act like a BEC of sorts? I know when I had my Savox installed, I had to have a decent size capacitor wired right into one of the aux channels of the reciever
samuelsonmark71 is offline
Old 04-17-2012, 10:25 PM
  #3563
B00t13g's Avatar
Has anyone run into an issue where the steering linkage hits the servo? If so what was your fix?
B00t13g is offline
Old 04-18-2012, 03:00 AM
  #3564
BEC will be my next step, i notice the steering problems even when i let off the throtle dose not seem to get better.
J-RO is offline
Old 04-18-2012, 05:24 AM
  #3565
t0p_sh0tta's Avatar
Trader Rating: 35 (100%+)
Yes. I sanded down the back of the ball cup, and it worked fine. This was running an Orion servo. If sanding down the cup doesn't work, then you could always mod the servo case.
t0p_sh0tta is offline
Old 04-18-2012, 05:48 AM
  #3566
lewis4x4's Avatar
Yea... I also have to trim the ball cup as well as trim some off the Servo Case... Works like a charm now...
lewis4x4 is offline
Old 04-18-2012, 06:00 AM
  #3567
t0p_sh0tta's Avatar
I miss my SC.
Old 04-18-2012, 10:12 AM
  #3568
R/C Tech Elite Member
JayL's Avatar
savox almost requires a recv cap
TRP makes an alum 1 piece servo saver arm part, very nice part, loving mine. Search this thread and PM him, can't remember his screename
JayL is offline
Old 04-18-2012, 12:02 PM
  #3569
Trader Rating: 86 (99%+)
Truck was soooo good last night, I was having a issue with a off power push previous to last night and it magically cured itself , must have just needed some more runs on the tires and foams to get them broke in
WideOpenThrottle RC is offline
Old 04-18-2012, 12:04 PM
  #3570
Trader Rating: 32 (100%+)
I see and read waaaay too many savox servo problems.
Sure sOme have no problems but thats a small percent compared to the huge number of problems.
I advise that you steer clear from savox. Get it? Steer clear. Lol
Pimpin is offline
