tire?
ok, im running either proline dirt hawgs, alias 2.8" traxxas spike tires or proline hole shot tires in the rear. and the front i use either the traxxas 2.8" alias ribbed tires or proline 2.2" edge tires.im running a rustler with the velineon setup. now im wondering if i will get better traction up front if i use the same tires up front as the rear? now i know i wont get more driving traction cause its 2wd. im talking more turning traction. like would using proline dirt hawgs all around be better? or running the holeshots all around? this is just for when im running on my local dirt track which mostly is hard packed dusty conditions. unless its sprayed down with water.any suggestions? thanks
run proline truck calibers around for whitepark.
Originally Posted by nv529
(Post 7680741)
calibers
Calibers are some of the best tires i've bought and will continue to buy more.:nod:
Originally Posted by kman16jr
(Post 7680922)
Originally Posted by ckblood05
(Post 7680943)
yea i hear there good tires. its just i went to proline.com, and when you click the 1/10 truck icon on the left, then the pick by kit and select electric rustler vxl, the caliber tires are not a choice in the category. and it says rear tires on them. they will still work good up front?
Originally Posted by LunchboX3904
(Post 7681040)
that's cause the stock wheel is 2.8". get some 12mm hex 2.2" wheels like the hpi scorch ones and you're golden. http://www3.towerhobbies.com/cgi-bin...orch&search=Go
do most of you guys prefer to run treaded tires up front on a 2wd truck instead of ribs?
Originally Posted by mcdragon2
(Post 7681064)
