Perfect Motor/ESC for a B4 >
Old 07-14-2010, 01:27 PM
Default Perfect Motor/ESC for a B4
Whats the Perfect Motor/ECE for a B4??????
I was thinking a Tekin 13.5 motor and Mammba ESC....
Any hints
thanks guys!!!!
Foxman1016 is offline
Old 07-14-2010, 01:32 PM
RDOUBLEDAY's Avatar
tekin with tekin dudee.
RDOUBLEDAY is offline
Briguy's Avatar
Trader Rating: 125 (100%+)
Tekin all the way !
Briguy is offline
Old 07-14-2010, 02:09 PM
Tech Legend
Cain's Avatar
Trader Rating: 252 (100%+)
used a variety here from novak, tekin, castle, and speed passion.
haven't found a truly "best" ESC etc. I would say determine the rules of your class, and find out what ESC offers the best features for that class.
example:
If you are running a 17.5 stock class with no timing limitations, you would want a Tekin timing advancing style ESC and not something like say the novak havoc 2S without timing advance features.
If running full mod like I do, I haven't found an need for the timing stuff.
one thing to consider though is that the ESC fits properly on the chassis. The Tekin's are nice and small, a plus for sure in a buggy.
Cain is offline
Old 07-14-2010, 02:34 PM
Chimer's Avatar
Trader Rating: 26 (100%+)
I am running mod with a Novak GTB SS and a Novak 7.5 Velocity Light Motor.
Chimer is offline
Old 07-14-2010, 02:36 PM
cantrell8's Avatar
tekin esc lrp x12 motor.. you cant go wrong!
cantrell8 is offline
Old 07-14-2010, 02:48 PM
TNS Racing's Avatar
id go with the new novak kinetic esc and ballistic motor. This is setup you'll have for a very long time
TNS Racing is offline
Old 07-14-2010, 02:51 PM
Briguy's Avatar
That is true for any top name brushless .
Briguy is offline
Old 07-14-2010, 02:53 PM
TNS Racing's Avatar
and if anything goes wrong with your novak system their customer service and warranty is outstanding
Old 07-14-2010, 02:55 PM
Briguy's Avatar
The same with Tekin , LRP , and Xcelorin . What is your point ?
Briguy is offline
Old 07-14-2010, 02:57 PM
cantrell8's Avatar
what class are you going to be running?
Old 07-14-2010, 03:03 PM
Tech Legend
Cain's Avatar
if warranty is important, I do have to give it castle creations as the best on paper (they have excellent customer service too by the way) as there warranty is the longest at 1 year. The others unless something has changed are limited to about 120 days.
Cain is offline
Old 07-14-2010, 03:09 PM
I use a hobbywing xerun paired with a epic duo 2 13.5. Fast and smooth. Size is bigger than a tekin but the b4 has the space for it.
Threg is offline
Old 07-14-2010, 03:16 PM
Revlimit's Avatar
Speed passion GT 2.0 LPF loaded with the 528 stock software, with a BOSS 17.5 would be awesome for stock with no timing limitations. Or load the speedo with 508 no timing software for limited timing classes. I run a GT 2.0 with the 528 stock and a BOSS 13.5 on oval with my FT B4and can easily keep up with 7.5s. And to boot Nathan at BOSS is a GREAT guy to work with!
Revlimit is offline
