Air esc in 1/8 e-buggy mechanical brake setup
Like title says, i'm curious as to if perhaps an airplane or helicopter esc would work in my 1/8 buggy with mechanical brakes. Since the only thing I need the neu motor to do is go forwards, theoretically speaking shouldn't i be able to use a air esc in my buggy? The only problem I forsee is maybe the cogging & calibration of esc. Can anyone shed some light on this?
cogging for sure. For 1/8 i would just make sure the air esc can handle 6s lipo and minimum 160 amps continuous.
sounds like a bad idea to me. im sure the esc would be fine with the constant amps (think some helli's and airplanes might draw more amps constant) but 1/8 scale electric draw some serious peak amps during acceleration........i just dont think they would put up with it but i could be wrong.
well, the castle esc is rated for 120a constant, soooo...................
I know someone with a Quarkmaster 125 in his LST conversion with mech brakes. He says it baraly gets hot.
Deosn't a decent airplane ESC cost as much as an RX8 anyway???
sooo like i said the "constant" amp rating would be fine sooo what does that have to do with peak amp draw?
i just didn't know if the esc's peak amp rating would be enough. it just seemed like an 1/8 scales acceleration was more violent than a airplanes that's all and that just because your esc can handle the constant amp draw doesn't mean it can necessarily handle the peak draw.
but sounds like a few have tried it and it was ok
there are alot of problems with running an air esc, the most important being that
air esc's run a different throttle setting, which you should be ok with if you run a computer radio, it all depends on what it takes to arm the esc, otherwise your going to find you need to rubber band your trigger at full brake.
Second alot of the fets they use in plane escs are not designed to wipe heat like car and boat escs, making them a little more fragile, all depending on the esc of course.
most electronic components, in my experience, have similar peak ratings given a similar constant rating. only problem in this case would be heat dissipation under burst loads IMO.
