jammin scrt 10 body mods for standard wheel size?? >
Old 07-07-2010, 05:17 PM
Trader Rating: 50 (100%+)
Default jammin scrt 10 body mods for standard wheel size??
I am thinking of getting a Jammin SCRT 10 truck and have heard about the weak front bumper which is an easy fix with the t bone bumper, but I have also heard that the wheels are slightly smaller than a standard short course wheel, meaning you are stuck with the stock wheels/tires.
So my question is, what do you have to do to make standard 2.2/3.0 wheels and proline or AKA tires to fit? Do you have to make body mods? What bodies are available for it beside the stock one?
I would love to see pics of some SCRT 10 trucks running standard SCT tires.
Are there any other weak points that should be addressed right away?
Thanks guys!
richvarner is offline
Old 07-07-2010, 06:35 PM
Slash rear wheels fit perfectly on front and back thats what most ppl are using. Youll have to trim your org body a little bit or you can buy the new Proline Desert Rat 2.0 body made for the SCRT
I use the slash rear bead locks for my front and rear and the desert rat body, thats my setup atleast, hope that helps
MWilson79 is offline
Old 07-07-2010, 07:14 PM
that does help.
anymore weak spots on the truck?
do the tires rub on the desert rat body or do they fit nicely?
Old 07-07-2010, 08:21 PM
WhiteFoxAz's Avatar
Trader Rating: 27 (100%+)
So my question is, what do you have to do to make standard 2.2/3.0 wheels and proline or AKA tires to fit? Do you have to make body mods? What bodies are available for it beside the stock one? The stock wheels are not the standard 2.2/3.0 wheel/tire but they are still 12mm wheel hexes so you can run any SC wheel(s)....Proline, J Concepts+++. The same goes for bodies. AE SC10, Proline Slash bodies, J-concepts Dare, Truth and Manta bodies all work!! It is personal pref. on which one! Go to the Jammin SCRT 10 thread!!! Has all the info you need and more!!!
Go to the SCRT 10 thread!!!
Thanks guys!
WhiteFoxAz is offline
Old 07-07-2010, 08:34 PM
jmackani's Avatar
Trader Rating: 14 (100%+)
that does help.
I use the manta blitz body on mine with slash rear offset all the way around and no trimming is required. The screws do come out of the rear bumper at times also. Keep a supply of body mounts also that mount to the shock towers until you get used to driving. Flipping it over a few times usually results in snapping them.
jmackani is offline
Old 07-07-2010, 08:37 PM
Trader Rating: 21 (100%+)
Thanks guys!
You want more info? Check out the Jammin SCRT10 thread....
jerryboy318 is offline
Old 07-08-2010, 04:58 AM
Thanks guys! I did see the SCRT 10 thread but it is 400 plus pages!! I had a few questions about it and it would literally take me 2 days to read that whole thread .
I got about 20 pages in and had to get back to work!!
Old 09-29-2010, 05:42 PM
hyperguy's Avatar
Trader Rating: 22 (100%+)
u can also use hpi wheels they have the same off set as traxxas and u have a couple more styles to choose from....and as for bodies u can make most any of the sc bodies work... trim alil here trim alil there and presto it fits
hyperguy is offline
Old 09-29-2010, 06:53 PM
R/C Tech Elite Member
thecman26's Avatar
Trader Rating: 106 (100%+)
I would recommend going through the 40 plus pages on the scrt-10 thread, there is a LOT of information covered and there's no easy substitute but patience and reading! Take notes!
thecman26 is offline
Old 09-29-2010, 07:37 PM
Trader Rating: 35 (100%+)
Everyone came out on this one to point to the main SCRT thread. Interesting.
marooko is offline
Old 10-01-2010, 06:11 AM
racerx1920's Avatar
Trader Rating: 216 (100%+)
i ran this body one mine when i had it
http://prolineracing.com/bodies/chev...ado-1500-slash
and these wheels
http://prolineracing.com/wheels/spli...-piece-wheels/
this picture has the AKA 1/8 pro five wheel on it with hotracing 17mm adapters for the hpi blitz
Attached Thumbnails jammin scrt 10 body mods for standard wheel size??-dirtburnerindoor-01-7%5B1%5D.jpg
racerx1920 is offline
