Old 05-25-2004, 03:41 PM   #1
t3guy's Avatar
Default What are CVDs and diffs?
Physically on my truck, what(where) are CVDs and the diffs?
t3guy is offline   Reply With Quote
Old 05-25-2004, 05:09 PM   #2
OvalEvader's Avatar
Send a message via AIM to OvalEvader
The CVD's are your axles. The diff is the part that distributes power to the side of least resistence. For example, when you hold one wheel, the diff sends all the power to the other wheel. The diff is at the back of the truck, in the gear box.
OvalEvader is offline   Reply With Quote
Old 05-25-2004, 05:11 PM   #3
mafiaracers's Avatar
Trader Rating: 22 (100%+)
Send a message via AIM to mafiaracers Send a message via MSN to mafiaracers
Are you serious? .....NO, I'm Just Kidding! The CVD's are the drive shafts that connect from the transmission case to the rear wheels. Those things sticking out of of each side of the transmission case are your diff halfs....if you take your transmission out and apart, the big gear with the most "buisness" to it, is the diff. If its not outside the car, you can't see it.
mafiaracers is offline   Reply With Quote
Old 05-26-2004, 04:39 PM   #4
corvettecrazy's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to corvettecrazy
CVD's : constant velocity drives They do the same thing as dog bones, except they have less play because the there is no lower half shaft to wiggle in.
a Diff ifferential : splits the input (power comming from spur gear) in 2 outputs so each wheel can be powered and drive the car)
corvettecrazy is offline   Reply With Quote
Old 05-26-2004, 05:04 PM   #5
hopefully this picture helps expalin a diff.
Old 05-26-2004, 07:39 PM   #6
t3guy's Avatar
ok thanks everyone, but i think corvette helped get it across--so it's not just one part or two, but its more of a whole casing?
and so CVDs are just improved dogbones?
ay ay ay! yea i know but hell u gotta learn somewhere
Old 05-26-2004, 08:22 PM   #7
CVD's this might help or it will mess you up...(hopefully help)
http://www.hpiracing.com/walkthroughs/rebuild-cvd.htm
The threads are where you screw on the wheel. The CVD reduces slop by making one of the dog bone ends "solid" (they are not really solid since they rotate and move and the joint) CVD's are generally stronger than the dogbone setup also. So yeah they are improved dogbones, although they will cost you more bones too...(more money)
Diff: yes they are a bunch (I cant give an exact number because there can be different numbers depending on the diff) of gears that transfer the power from 1 input to 2 outputs. Most are cased in plastic, although Aluminum cases are avaible(I wouldn't advise using one though).
We all didn't know this info at some point and had to learn it, your learning time is now and there is nothing wrong with that. Keep asking questions and you will keep learning
Old 05-27-2004, 07:23 PM   #8
t3guy's Avatar
Ok thanks vette. Now i got most of it, cept im still missin a few pieces.
As far as what the CVDs actually do , im kinda foggy on that...
And the differentials....also kinda foggy on exactly what they do.
Arg thanks again everyone--i'll learn sometime
Old 05-27-2004, 07:49 PM   #9
CVD's take the power from the diff and transpher it down to the wheels. That is their job.
as for the diff and what it actually does. The best description I have is that it takes the power from 1 source and splits it into 2...sorry I cant put it into any words that make more sense Its a tough thing to explain.
Old 05-27-2004, 11:11 PM   #10
Aaron Waldron's Avatar
A differential's main purpose is during turning..the outside tire has to travel a further distance than the inside tire, and a differential ensures that the outside tire will spin faster.
Aaron Waldron - LiveRC
www.liverc.com
Aaron Waldron is offline   Reply With Quote
Old 05-29-2004, 08:16 AM   #11
t3guy's Avatar
OOoooh ok thanks Aaron (and Vette) now i know what the differential is all about. And yes, I'm sure I understand everything haha. It has be come clear....
metal spider diffs or ball diffs in mini inferno? JEFFRO503 Micro and Mini Scales 3 01-11-2008 11:48 AM
XXX CR cvds/ XXX BK1 theanimaleide R/C Items: Wanted to Buy 3 09-21-2007 09:27 PM
NIP Savage Bulletproof diffs, MIP CVDs, LST tires!! yahhoo R/C Items: For Sale/Trade 0 10-02-2005 02:43 PM
Ball diffs versus gear diffs Cole Trickle Electric On-Road 20 05-16-2003 04:43 PM
One-Way Diffs vs. Diffs in Kits eBoi31 Electric On-Road 14 04-13-2002 11:02 AM
