Stripped metric screw.
+1 to the above.
If that won't get it take a dremel with a THIN cut-off wheel and make a slot right across the recess for the hex bit... use a standard or flat head screw driver THAT FILL's THE SLOT!!to remove the screw... make sure you heat it up real good before you even try to remove it.
I always carry a set of ez outs AKA grabbit. Everyones best friend at the track!
Good tip! I'll save my worn wheels next time.
