new problem with xxxt? help >
Old 06-29-2010, 08:34 PM
pdiddy777's Avatar
Default new problem with xxxt? help
finally put in my new lipo with mamba brushless esc and the 5700kv.. this thing is so freakin fast ,but my problem now is that when i floor it while drivin it makes a loud rrrrrr sound ..like its slippin real hard .. but if i gradually pull trigger it doesnt do it ..its like there is too much motor for it .. i adjusted the slipper from all the way tight too loosening it ,,did nothing either way . i ran a nimh battery b4 and didnt have any issues ,now with lipo which is 10xs faster now i have this problem ..please help !! do i have to adjust the esc ? or the slipper ? who knows?
pdiddy777 is offline
Old 06-29-2010, 08:37 PM
RDOUBLEDAY's Avatar
you need to tighten your diff
RDOUBLEDAY is offline
Old 06-29-2010, 08:43 PM
pdiddy777's Avatar
Default ..
i tightened it all the way down ..still does it no difference.. til the spring was locked
Old 06-29-2010, 08:46 PM
pdiddy777's Avatar
sounds like at full throttle its just too fast ..its a new tranny , and had no issues until i got this crazy speed now with the lipo
Old 06-29-2010, 08:56 PM
Do you mean the slipper spring? I also suspect you need to tighten the diff, the screw inside the left outdrive behind the dogbone/driveshaft.
Donít overdo it though. Check by holding both rear wheels and turning the spur gear by hand. The slipper should always slip before the diff, meaning the slipper spring and nut should not turn with the spur gear.
Dave H is offline
Old 06-29-2010, 09:09 PM
Briguy's Avatar
Trader Rating: 125 (100%+)
Like mentioned that sound is your diff inside the tranny slipping . Tighten it up before running again or you could melt the diff gear . Also , once you have the diff tight you want to set the slipper to slip a bit on take off , usually 1-3 feet depending on track conditions .
Briguy is offline
Old 06-30-2010, 04:02 PM
pdiddy777's Avatar
Default ok
u guys were right that did it .. new problem ..now it goes so fast it does a back flip everytime i put on full throttle .. .. do i have to dial down the esc .. if so how should i set it ? or what can i do now
Old 06-30-2010, 04:05 PM
Briguy's Avatar
You can turn down the throttle on your radio , possibly turn down the ESC depending on what brand it is , and loosen the slipper up .
Briguy is offline
Old 06-30-2010, 04:10 PM
pdiddy777's Avatar
its a mamba ..i can change it on the laptop ..but how should i set the throttle curve?
