Serpent S811 Cobra, Brushless...
#46
back to work today after the great winter storm of 2011 here in alabama ..heres the rx8 set up i ran at the opening race ...tight track ...great traction ....the only thing i may do is drop 1 tooth off the pinion and run a 17t ....other than that it was dialed ...mtr never got over 130and esc hovered around 115-120 ...never even checked it after the second heat race
#47
Anyway, raced my RCM converted 811 for the first time Saturday. Still getting the setup tweaked for my driving style. Car was fast in the main, I just kept wrecking for no reason. Still needs a bit more steering, but I have a few ideas for that.
#48
Lol, just looked at your RX8 profile. Wow, you do know that drag brake and push control oppose eachother? Why do you have both active?
#51
Still some things I want to try before chaning diff fluids. Put more droop in the car front and rear, went back to losi green rear springs. Still have to play with front kickup and the LR rear toe in block.
#54
#56
Drag brake is just like it sounds. When you let off the throttle its a constant load it puts on the motor. Similar to the driveline not free rolling. Push control is when you let off the throttle the car then uses X amount of delayed throttle to continue to move the car. Like if you were to say full throttle is 100 and idle is zero, push means depening on the value it can hold 10% throttle for X amount of time after the throttle goes to zero. I tried it and didn't like it. The buggy was not consistent when letting off. Alan if you need any setup help with the tekin or the motors just give me a shout. Heck me and zixxer talk daily or every other day.
#57
Sticker Printing
i always like to read some good and informative
blogs and this blog is also so good and helpful.
thanks for taking time to discus this topic..
#58
