suspension pins bending!!!
i keep bending the suspension pins on the front of my rustler. this is like the fourth time. i have rpm caster blocks. whats happening is the caster blocks are bending, not breaking, but when they bend, its allowing the pins to bend. i think i need to get the alluminum caster blocks. they shouldnt bend. im getting tired of ordering pins and replacing them :flaming: any advice?
Are the pins steel? What on earth do you keep hitting?
Well I hate to sound like a d--k but it would help a lot more if you stopped crashing into things that causes the pins to bend.
Originally Posted by Razathorn
(Post 7554611)
(Post 7554611)
Originally Posted by AreCee
(Post 7554619)
Originally Posted by ckblood05
(Post 7554631)
i never said im crashing into things. i jump about 6+ feet in the air sometimes. plus i hit the front side of the jump on a double some times.
That by definition is a crash, i.e., Lawn Dart, Casing and Chassis slapping are all forms of crashes. |
im thinking about getting the trx aluminum caster blocks. theres another brand called st racing. which would you recommend?
yep, those vertical pins bend really easily. There are two traxxas pins that are almost the same length, but one is slightly longer- you should be using the longer ones.
I replaced mine with the thicker traxxas kingpins that use eclips on both ends. You have to drill the hole a bit bigger, but they are much more solid. I don't know what vehicle they are made for, I think they are for the nitro rustler. |
(Post 7554638)
And that is what you consider not crashing?????
That by definition is a crash, i.e., Lawn Dart, Casing and Chassis slapping are all forms of crashes. http://www.buytraxxas.com/product_in...roducts_id=946 |
Originally Posted by bennybtl
(Post 7554639)
When ypu break (bend) stock parts, try to upgrade or expect more of the same. These are Ti - will be stronger than what you're bending now (soft steel) -
http://www3.towerhobbies.com/cgi-bin...&I=LXVAH4&P=ML Or from Lunsford direct - http://www.lunsfordracing.com/mm5/me...Code=TRUC-TRRU |
Originally Posted by Duster_360
(Post 7554669)
check out www.teamstrc.com. Trx e-clips/pins need more strength.
Originally Posted by bowl806
(Post 7554788)
http://www.teamstrc.com/ebproductdet...inid=42&id=425 |
