The higher the voltage the lower the amperage draw will be. This relates to anything electrical, which is why lights in most all large office buildings and factories are run on 277/480v instead of 120/208v or 110-220v. The same applies for motors and such for elevators and assembly/ manufacturing factories.
I finally finished my Ve8 and put a 1400kv tekin on 2500mah 30c 6s and took it out in front of the house. It sure is smooth but doesn't seem to have as much power as my 2200kv on 4s. Is that because of the torque of the 2200kv? I just want to make sure I have enough power to get around the track.
Originally Posted by tom2tone
(Post 7555176)
Originally Posted by TD-Ent
(Post 7555143)
Ok, along these same lines, how about going from a 4s/1900kv setup to a 5s/1900kv setup, BUT, also going from 16/48 gearing to 15/50 gearing?
(Post 7555176)
Here ya go. The first site tells you how to gear your setup for the same speed:
http://scriptasylum.com/rc_speed/_top_speed.html the second site tells you how many amps you are pulling, along with other info: http://scriptasylum.com/rc_speed/_speed_amp.html (In an Austrian accent) Go there! Go there now! |
question ??????? so if i buy a high c rated pack -like 50 c 4s lipo is not the going to help any thang, like heat
what mah 5s lipo do i need for a buggy to run 15 minuts? so i guess a 3s 5800 lipo will not lower any heat in the speed control or motor? |
Originally Posted by LOSIRACER77
(Post 7555750)
Yes, it will help lower the temp of the battery because the higher "C" rated packs have lower internal resistance. what mah 5s lipo do i need for a buggy to run 15 minuts? Id start with a 4000mah and see where that gets you. so i guess a 3s 5800 lipo will not lower any heat in the speed control or motor? Compared to the higher cell counts, no. |
So let me get this straight in my head. It seems that esc temps are more dependent on the motor than on the batteries? If we lower the Kv of the motor we must increase the voltage of the pack in order to get a competitive speed. So if I were to switch from a 1900Kv motor to a 1700Kv motor and still use 4s I would be sacrificing speed but my esc would run at a lower temp. am i understanding this correctly? I am sorry if this has been covered many times before but I'll be willing to bet I am not the only one slightly confused by all of this.
Originally Posted by fievel
(Post 7555862)
Originally Posted by reracer
(Post 7554555)
Now, if we could only get ROAR to see the light...
(Post 7555862)
In my experience, I haven't noticed a significant differnet motor temps regardless of the setups and I have raced everything from 3s to 6s. What creates temps more than anything is ensuring the motors have enough torque. This is why the four pole motors such as Neu, Castle, Tekin, adn Xerun run cooler than the two pole motors from Novak, LRP, etc. |
Originally Posted by Edumakated
(Post 7556771)
Amps are what create the heat in the ESC. When we use higher voltage, the less amps are needed to create the needed power, so the ESC runs cooler. The same is also true of the batteries. The higher voltage setups are easier on the batteries which is why you can get away with running lower C rated packs because the battery doesn't have to work as hard to supply the needed amps (which is why higher voltage setups use packs with less overall Mah for the same run time).
(Post 7556799)
see i got a 5800mah 3s with 35c rate. and the 4s i got is 5200 mah 40c, i guess i need high c rating packs like 50 c??
(Post 7556868)
Not necessarily... anything over 30c is usually adequate. However, the lower the voltage, the stronger you want your batteries (higher C) generally speaking since the lower voltage setups are going to require the batteries work harder to deliver the needed power.
| All times are GMT -7. It is currently 09:01 AM. |
