Gt7 Help!!
It just sounds like you need to set up up again. Read the manual on how to set it up exactly. Its been awhile since I set mine, but I know you have to hold the setup button while turning the power on, you'll grab full throttle, full brake, and neutral, but I don't remember what the LED indicator do do each is. If you don't have it, here's a link to the manual.
http://www.teamnovak.com/Download/acrobat/GT7_ins.pdf |
HeY!!!
Brandon i had that also when i first set mine, but i thought immeadietly i did something wrong so i reset it and it was golden....(i have futaba magnum) |
Adjust the end points for the Throttle on your radio. That should get you to STOP at the neutral trigger position. :nod:
[QUOTE]Originally posted by Maxx Racer
Adjust the end points for the Throttle on your radio. That should get you to STOP at the neutral trigger position. :nod: [/ Mike is right, set your end points first, then it should work properly. |
