SLASHLER PICS THREAD
POST UP YOUR PICS OF ALL RUSTLER SLASHES.
INFO AND PICS WILL BE AWESOME. IM TRYING TO BUILD MINE NOW
ok
I took two Rustler chassis(es?), and cut each one in half, but in two different spots:
I then took the longer rear end from one chassis, and the longer front end from the other chassis, put them together to replicate the Slash wheelbase, and voila:
I also ended up with a very short wheelbase chassis that could generate some laughs...
Next, I will join the two halves with 1" x 1/16" aluminum "L" angle. I am not done yet, but am working on it when time allows. I will then use this chassis for my Slash in the 2WD stock class at the Short Course Nationals.
very cool with the 2 rustler chasis put together . show some more pics after you put it together . very creative . thanks !!
Late October 09 finished 3rd in Mod SC
http://www.t3t4webservice.com/Rustler_SC.html
Early December 09 finished 1st in Mod SC
http://www.t3t4webservice.com/Rustler_SC_2.html
Like this the best because you can go back to ST class in less than an hour!
I don't know much about short course so my question is, whats the point of this? Does it handle better?
keep the pics comming and
@one8updragracer it makes the slash have a lower center of gravity which = better handling and turning. and it also lightens it up and slims it down.
nice does having the tread mount, backwards in the rear really help you gain traction ?
what stock motor are you using ?
and i use a 7 cell and was sliding, around with the tread mounted foward in the rear.
To get a "Extended" SC to handle you need to move the battery back about half the extendtion you added. With a Rustler you will need to cut out (remove) the rear battery wall.
I've built a "Extended" Rustler, "Extended" Losi XXXT and "Extended" Druatrax ST all had to have the battery area lengthed OR 1 and 1/2 oz of weight added in the "Extended" section. These are all race SC's not play in the front yard trucks.
Although this isn't a Rustler, this shows that "Extenders" is NOT just a home mod any more!! :-)
http://www.teamcrc.com/crc/modules.p...prodID=7719120
