PROBLEMS!
PROBLEMS!
i bought a used 4wd traxxas slash! yeehawww! yeah right its a non-platinum and i run a 4200mah 3s lipo i've turned it down on the radio (DX3R) and i keep blowing apart the outdrives in the rear end is there any upgrade thats out there to correct this problem?i'm also racing the stock slipper clutch not too tight and the traxxas brushless system!do you think that the 3s is too much for this truck?please help!
R/C Tech Elite Member
I'm pretty sure there are metal outdrives.
issues?
if i install metal outdrives that will only mean thatsomething else will end up breaking!wont it?
3s lipo 40c
19pinion
54 spur
standard traxxas brushless system
dx3r radio 75% power i turned it down and still breaks rear hubs.
i bought new ones today ran at my track and they didnt break now the front yoke on the axle broke!i up graded to jato rear mip cvd's (which are the same length)but now the front breaks!what gives!
3s lipo 40c
19pinion
54 spur
I would lower your pinion and double check here:
http://www.scriptasylum.com/rc_speed/_top_speed.html
So how fast is you slash? I know quite a few people running 3s in theirs and not having any problems. you will go through drivshafts faster having more power, but not that quick. If you try to land before you get on the power will increase the longevity of them too.
I have had my 4x4 since the day they were released and I havent broke one front drive shaft. How many have you wrecked?
I don't know much about the 4x4, but I have a 2x4, and if your slipper clutch is turned down too tight, bad things happen. You should try to loosen your clutch.
Sorry but you have to be driving like a jacka** to break 8 in a day.Thats $80 in drive shafts. I get like probably like 20-25 3s packs on a driveshaft before they start getting worn out. especially fronts.
