mamba max pro and 4.5 hv >
Old 07-19-2010, 02:09 PM
  #31
murky123's Avatar
try this cheap BEC from hobbywing. I have it running in my slash 4x4 with the MMP + hv 4.5
no glitching. nada nothing.. you can get this for around 8 dollars on ebay
murky123 is offline
Old 07-20-2010, 09:09 AM
  #32
NeverATiteLine's Avatar
Originally Posted by NeverATiteLine View Post
I had this problem w/mine, plugged in a capacitor and BAM problem solved. Now I am having a cog issue. I am going to try switching from smart cence to censored, I have a feeling that will fix the issue.
ill update after I try it later tonight
This did indeed work, no more cogging!
NeverATiteLine is offline
Old 08-15-2010, 11:23 AM
  #33
My velineon ESC burned up so I replaced it with a MMPro on my Hyper 10 with a 4.5HV.
It's horrible, it would continually glitch and I'd lose steering, everything.
I'm going to try a glitch buster, hopefully it works.
Toddzilla is offline
Old 08-15-2010, 12:58 PM
  #34
spy2jgc's Avatar
TheCapp/glitch buster worked great for me... a night and day difference. Then I got some high amp high discharge batteries that let me remove the CAP, but I left it in.
spy2jgc is offline
Old 08-15-2010, 01:22 PM
  #35
simplechamp's Avatar
Trader Rating: 73 (100%+)
I was experiencing same issues as most people, the servo was drawing too much current, causing the BEC to cut out and the RX to lose power. Added a big cap and it seemed to fix the problem. Probably will switch to an external BEC eventually, just need to get around to wiring it up.
I think their are 2 separate issues: the servo overloading the BEC, and 2-pole sensored motors cogging. But when both problems happen at the same time it seems like one big issue. Try a cap first and get the BEC to run smoothly without cutting out, then you can work on solving motor cogging issues. The reason I say it's two separate issues is because I have only run with 4-pole sensorless motors, and cogging hasn't been an issue at all, but the BEC overloading still occurred.
simplechamp is offline
Old 08-15-2010, 01:40 PM
  #36
Ran out to the LHS, got a glitch buster for $6, tried it out on the track for 5 minutes and so issues.
Problem solved!
I did notice a little bit of cogging that i didn't have with my velineon.
