Old 05-12-2004, 10:36 AM   #1
Send a message via Yahoo to SLOWONE
Lrp Qc 2 Esc
NEED SOME INFO ON SET UP MAPPING WHEN USED WITH JR-XR3I
CAN NOT GET BRAKES AND THROTLE TO ADJ AFTER SET, EVERYTHING ELSE WORKS GREAT
SLOWONE is offline   Reply With Quote
Old 05-12-2004, 01:38 PM   #2
What are you trying to adjust about the brakes and throttle?
AE Racer is offline   Reply With Quote
Old 05-12-2004, 04:53 PM   #3
need less power for a slick track and i have to much brake when jumping
Old 05-12-2004, 05:28 PM   #4
What wont it let you adjust? It wont let you adjust EXP on your radio? If you set it up right it shouldnt have any brake at neutral, unless the stock setup has some drag brake, but I am 90% sure it doesnt. You can also adjust punch control right on the ESC read the directions it couldnt be any easier to adjust. If you're trying to say that when you hit the brakes a tiny bit its too much then you need to turn the initial brake down to zero, initial brake is also adjustable on the ESC.
