10sc????
#16
I think youre gonna like it a lot , the drivetrain is near bullitproof and once you get it set up it drives like a 1/8 buggy and is a very fun ride .
What motor/ESC are you getting ? Did you get the Tim Bump Edition ?
#18
thanking of getting the 10sc. i race the sc10 now and love it but my home track is letting the 4x4 slash run in the mod class and theres no way the 2wd can beat the 4wds. is the 10sc a good truck, and how is the parts support. also does anyone know if a sc10 body will fit on it?
#19
Congratulations man. You're going to dig it. I love mine. Head over to http://www.rcshortcourse.com/forum/f...play.php?f=105 if you already haven't, lots of good information there.
#20
http://www.nitrohouse.com/catalog/articles.php?tPath=16
#22
Spacers on the shock shaft is needed, also you may want to look into the jammin steering mod. It makes a good difference when on a small tight track.
#27
I am runiing the Bump setup , but I am using 2000wt in the front and its feeling really dialed on my track , cant wait till next race day Gonna put a hurtin on some Slash 4x4's !
Stock the front and rear just have grease in them and the center had some oil in it but I dont know the weight and mine felt loose and wouldnt accellerate the way I like after I filled all the diffs it was a big improvement .
Another thing you might want too look at is moving the battery tray back 32mm since you didnt get the Bump Edition .
#29
Sure , here you go ... Sorry the pic is so bad ...
#30
I thought only the original release Hyper had grease, and that was only in the rear diff. I believe the updated version comes with oil in all three diffs. I haven't opened them up yet, so I could be wrong. Also, the newer kit comes with the spacers required for the rear shocks to prevent bending the dog bones. Just make sure you put them one when you build the shocks. Another tidbit of info, I'd recommend using some form of lubrication on the center dog bones. I assumed they had been greased from the factory, but after a few races they were showing tremendous wear.
-melon
-melon
