RC8E opinion on pinion
im rockin my new 1500series nue 1800kv 80 amp in my rc8e, i just switched it from the 2650. after some calculations i figured that with a 20 tooth pinion w/1800 should have close to the same speed as the 15/2650. what is your opinion, what pinion should i be running in my rc8e w/1800kv motor 4s?
The front and rear diffs appear to be 4.3 ratio. The stock spur in the RC8Be is a 46 from what I can see. At OC/RC the team setup used a 17 pinion but of course did not list the motor KV, so no help there. I will work it back using my tried and true 35 mph settings. With standard buggy tires (4.3 inch tall) it works out to a tire rpm of about 2700 or 11610 rpm at the center diff. With an 1800 KV motor on 4S, you have a motor speed of 26640. So you want a ratio close to 26640 / 11610 = 2.295:1 or 46:20
So I agree, the 20 tooth will put you right in the ball park, maybe a 19 on a tighter track like OC/RC or Hot Rod Hobbies. I usually end up geared more like 32 mph at these places, but you will not be hurting anything with a 20 on there.
Tech Legend
here is a calculator for you:
http://scriptasylum.com/rc_speed/_top_speed.html
works great for comparisons. When i ran the 2050kv neu wasn't odd for me to drop in the 20T pinion.
what run times are you guys getting with the rc8e with the mamba 1800KV motor and 4s 5000mah pack? and temps?
