Old 05-10-2004, 09:22 PM   #16
Aaron Waldron's Avatar
It is fine to run your truck out of gas at the end of the day, but I would not do it every time.
runnin rc10 - Check your coupler, pressure line, and where the header attaches to the engine (there should be a gasket there).
Aaron Waldron - LiveRC
www.liverc.com
Aaron Waldron is offline   Reply With Quote
Old 05-12-2004, 09:51 AM   #17
JoshR 85's Avatar
HeY!!!
Thanx Aaron, i'll try to always tap fly wheel befor i run outa gas then, i'm still new to this nitro stuff. would you happen to know a good setup for a losi XXX-NT...(not the ade)??? thanx
JoshR 85 is offline   Reply With Quote
Old 05-12-2004, 10:04 AM   #18
warpig's Avatar
to add.. you need to make sure and burn all the fuel.. you do not want any fuel left in the engine at all.. after the tank is empty I put my ignitor on and throw it on the starter box.. 20 seconds or so to burn all the excess fuel..
I run my engine out of fuel all the time while driving.. I usually can feel the engine cut out.. then I bring it it and let it run out of fuel.. I don't continue to drive it after it cuts out though..
warpig is offline   Reply With Quote
Old 05-12-2004, 04:19 PM   #19
corvettecrazy's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to corvettecrazy
I have to run it out of fuel...I dont have enough compression for the engine to run without backpreasure. . . which is gone when I refuel.
corvettecrazy is offline   Reply With Quote
Old 05-12-2004, 05:23 PM   #20
Josh - http://www.teamlosi.com/pictures/jpe...std_adam03.jpg
Setups for the stock XXX-NT and the Drake Edition truck are the same.
www.liverc.com
Old 05-12-2004, 05:23 PM   #21
warpig's Avatar
when you are done for the day.. you run it out of fuel..
you lost your compression seal?? that's a whole different thing then.. get a new engine
Is EB Mods shutting down? German Muscle Onroad Nitro Engine Zone 23 12-19-2008 12:19 AM
Shutting off the alt-tags rcg33k R/C Tech Site Forum 1 09-17-2008 02:22 AM
engine shutting down once its warmed up dundill Electric Off-Road 5 07-08-2008 05:21 PM
Crystal Park Shutting Down? nitrodude Nitro On-Road 46 11-20-2007 12:14 PM
TRC Hobby in Tea, SD Shutting Down? mitchb13 Minnesota and North/South Dakota Racing 7 03-20-2007 03:21 PM
