Traxxas slash Bodies
The stocker is the most durable. Some guys have run those for two seasons.
The Jconcepts Manta is cool looking. The SC10 bodies should fit the Slash.
There used to be a buggy class made up of converted Slash's. Don't remember who made that kit, or what that long gone class was called.
The JConcepts body is the thickest, most durable SC body out there.
Brushing on a layer of shoe goo on the inside will make your body last longer as well plus it helps protect the paint job from tire and nerf bar rub.
I have run them all. I have found that the Factory Slash Body, which is thin not thick as the last poster stated, has been the longest lasting body I have found. The Baja bug body is really thick and is holding up well, it is just not accepted at all races. I have run the Desert Rat, Silverado and Hardcore. These did not last long and had some defects from the injection. If you did any trimming with a razor when painting then it would always split on the line no matter how careful or shallow you cut. I will say it again, for me, the factory traxxas bodies have held up the best. It may have to do with the lexan being thinner. I should state that I only race I do not bash. If you are bashing then I would recommend the cheapest thing you can find and paint it with a rattle can.
