Old 05-06-2004, 08:01 PM   #1
BBHOBBIES's Avatar
Default RC10B4 Traction
Does any one have any suggestions on this one i run a RC10 B4 it handles great turns in and out of corners great but i cant seem to find the right Tire for Traction on my track ive Tried Tapper pins Step Pins and Hole Shots our track is Med sized Bumpy and Rutty (because we let 1/8th Scales tear it up) It is clay but it is really Dusty and Sandy and then Wet and Loose in some Spots but mostly Sandy and Dusty .Just looking for some Tire Suggestions i can try on these Conditions.
BBHOBBIES is offline   Reply With Quote
Old 05-06-2004, 08:11 PM   #2
Andrew_XXXs's Avatar
Try IFmar stud...
Sounds similar to our track over here and we run proline 8081's (except you can't get them over there).
Andrew_XXXs is offline   Reply With Quote
Old 05-06-2004, 08:19 PM   #3
sounds like a track where u need big threads ie ifmar studs
craziracer is offline   Reply With Quote
Old 05-07-2004, 11:31 PM   #4
check here for all your buggy set-up needs: http://home.tiscali.be/be067749/58/bug/print.htm
it has everything you would possibly want to know
later
Blazin'
BlazinB4 is offline   Reply With Quote
Old 05-08-2004, 09:29 AM   #5
BBHOBBIES's Avatar
Thank You for the Help
Old 05-08-2004, 11:55 PM   #6
Registered User
ritchie's Avatar
you can try the proline evil twins, on the inserts, cut about a 1/8 inch off the inside edge (so its beveled) and about a 1/4 inch of the outside edge. now it should look like kinda like a donut. you may want to try a lighter spring or shock oil or try a couple of washers under the inner ball stud on the rear shock tower. losi bk bars should also work. but don't cut the outter edge of the insert. i would start with the washers as it is the easiest and cheapest. how much anti swat are you using?
ritchie is offline   Reply With Quote
Old 05-09-2004, 09:21 AM   #7
warpig's Avatar
run ifmar pins they are dialed
.. and don't whine about 1/8 scales.. it is offroad after all
warpig is offline   Reply With Quote
Old 05-09-2004, 09:22 AM   #8
warpig's Avatar
you can trim the innner and outer rows of the ifmar pins and gain tire roll.. seems better that way
Old 05-10-2004, 10:00 AM   #9
JoshR 85's Avatar
HeY!!!
Andrew_XXXs... why can't we get those tires over here???
JoshR 85 is offline   Reply With Quote
Old 05-10-2004, 10:31 AM   #10
Administrator
Matt M.'s Avatar
Trader Rating: 26 (100%+)
step pins.....
Matt M. is offline   Reply With Quote
Old 05-10-2004, 10:49 AM   #11
aaronb73's Avatar
Try the new associated team / factory B4 standard setup with step pins, you shouldn't have any traction problems. I race on a very similar track, ruts and all. You just pick the best line you can and go for it...
You might have better luck using silver or green rear springs, black is really soft.
From kdubs post on rc10b4.com:
New Kit setup (for team and FT kits):
Front: #1, 30 wt, no limiter, Brown spring, 25 block, axles down, 2 bumpsteer, shocks 2-Out, link 1-A, 1 washer, -1 camber
Rear: #1, 30 wt, 2 limiter, black spring, hubs middle, 2 antisquat, link 1-C, 2 washers, shocks 1-In, -1 camber, battery back
This was developed over months of testing to make the car easy to drive. It works best on low to medium grip tracks, indoors and outdoors. It has good rear traction and jumps flat to nose-up.
Typically when I run this, I run either 32.5 wt mix oil or 35 wt all around. I also like a bit more down-travel all the way around. For higher grip tracks, try shortening the rear link to 'B' in the hub or going up to Green rear springs.
aaronb73 is offline   Reply With Quote
Old 05-10-2004, 03:26 PM   #12
Mr-s413bt's Avatar
Hey Aaronb.
How do i get the brown springs?? Can i order a spring kit???
Let me know.
Glenn
Mr-s413bt is offline   Reply With Quote
Old 05-10-2004, 04:22 PM   #13
aaronb73's Avatar
Unfortunately the two spring kits associated sells does not yet include the brown fronts or black rears.
#6493 Brown Front springs
#6481 Black Rear springs
Your local hobby shop or online store will have em. I've been running a setup very similar to this with green rear springs and 30 degree castor blocks. You will have almost uncontrollable steering !
Old 05-11-2004, 12:35 AM   #14
Ybakoff's Avatar
Originally posted by JoshR 85
HeY!!!
Because they are made specially for us and some where else like Germany or something.
We don't have many blue groove tracks here. So we need grip.
I will be getting some out later on ready to put on. I'll throw a pick on here for you.
Ybakoff is offline   Reply With Quote
Old 05-12-2004, 09:46 AM   #15
JoshR 85's Avatar
HeY!!!
ok thanx then and i'll be looking forward to the pic.... i geuss.
Gearing for Traction/Slipper for Traction RCRat Electric Off-Road 2 08-27-2008 03:55 AM
High-traction & low-traction? bloodlust Malaysian R/C Racers 4 12-06-2007 09:17 AM
How to get traction tc3=speed Australian Racing 15 04-24-2006 08:53 PM
Traction dontfeelcold Australian Racing 6 04-07-2004 07:25 AM
Traction xray racer Australian Racing 2 02-11-2003 03:52 AM
