slash shock pistons
1 Attachment(s)
does any body know what the things are behind these pistons and what do they do and where do they go on the a stock 2wd slash Attachment 594854
Those look to be spacers for mounting the top of the shock to the shock tower....
the smaller ones go inside the top of the shock tower, thru the shock and mount to the body post mount;the bigger ones are for inside the shock cap for 2 or 3 hole pistons.
k i will look into it
They are used to replace the stock shouldered screws that come in the slash. You can use those bushings with a standard 4-40 screw and nut to mount the top of the shock to the shock tower.
hey thanks for the info.... probably wont use them but will keep them around just never know.... thanks guys
